Old 08-14-2023, 08:34 PM
Il verze Il verze is offline
Post 2006 Gas Gas Pampera 400 oil leak from the breather hose
Hello everyone, I'm a new user of the forum, I'm Italian, so I apologize for any errors in writing.
I recently bought a 2006 Pampera 400 gas gas and noticed a massive oil leak from the breather hose on the cam cover.
The motorcycle also leaks if the oil level drops below the minimum level.
I can't figure out what could be causing this problem, much less how to fix it.
Can someone who knows more about this give me some advice?
Old 08-14-2023, 09:24 PM
blitz11's Avatar
blitz11 blitz11 is offline
My 1971 model year Honda SL100 broke a piston ring, and it wore a big hole in the cylinder, allowing exhaust gas to pass by and pressurize the crankcase.
It would blow exhaust and oil out the crankcase breather (the cylinder head wasn't vented.)
Have you checked compression?
Have you had the cam cover off? Have you checked for any missing baffle to keep oil inside the cam cavity?
Old 09-08-2023, 11:50 AM
Post
Hi, thanks for the advice.
I removed the cam cover and it seems like nothing is missing, now I'm getting ready to do a compression test to check if the piston rings still have a good seal.
I just have to mount the flywheel and starter motor to make sure the engine turns and read the compression data.
Crank Case Breather Hose Question Doc Brown Enduro Engine - 2 stroke 6 06-05-2020 09:37 AM
2006 Pampera 400 - Ignition Fault (No Spark) - call for help kaifus87 Enduro Engine 4 stroke (including EFI & Exhaust) 0 03-26-2019 08:43 PM
EC 3000 2011. Leak carb from the hose smitten Enduro Intake/Carburetion - 2 stroke 6 09-17-2016 09:31 AM
2011 EC250f manual---breather hose question forgiven Enduro Engine 4 stroke (including EFI & Exhaust) 7 09-11-2012 05:57 AM
Oil leak from breather pipe TXT pro 250 jamesukm General Discussions & Announcements 0 04-22-2010 12:59 AM
