Old 03-04-2013, 05:46 PM
Apex_4 Apex_4 is offline
Default Fuel pump replacement
hello everyone, I'm the new owner of an 03' 450fse
the bike doesn't seem to prime when the key is turned.
and b y some odd turn of events, my trusty volt meter is missing!
alternatively, I removed the fuel pump assembly and directly tested 12v on the pump motor, it received the power, moved very slighty but didn't turn like it was frozen.
is there anything I should check before ruling that the pump is bad?
if it is indeed faulty, where can I find a pump for a decent price?
can my current pump be refurbished?
any and all help is apreciated!
Old 03-04-2013, 11:29 PM
gasmonkey's Avatar
Bronze Level Site Supporter
First check your getting good voltage from the relay(back cover,rh side)bearing in mind it's a tachometricly controled unit.
The pumps have been generaly reliable.The wiring and switching not so.
Good luck finding oem.
In
an old thread here,someone used an airtex e7000 pump as a replacemnt.
I guess any intank 12v pump of similar dimensions would do the job.
Old 03-08-2013, 09:47 AM
In
Checked the relay and it was getting power.
Are there any specifications that I need to look for in a new pump? Does each pump have adjustable pressure and what does the gasgas call for?
Old 03-22-2013, 12:44 AM
Where could I find a pump like this?
What Else would I need for the setup? Ie pressure regulator?
Tags
fuel, pump
400FSE Fuel pump question Gi_GASGAS Enduro Engine 4 stroke (including EFI & Exhaust) 3 12-31-2019 03:58 PM
Looks Like I got A Bad Fuel Pump Boomhauer All Other Bikes... 11 11-22-2011 08:25 PM
03 450 fuel pump voltages query hillbilly Enduro Engine 4 stroke (including EFI & Exhaust) 1 09-22-2010 04:21 PM
Fuel pump relay-where is it? sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 19 08-26-2009 12:31 PM
