Old 01-23-2010, 10:49 AM
kendunn kendunn is offline
Default Rear hub bearing washer
I screwed up my rear hub bearing washer (the washer that goes between the two bearings) and I was wondering if there was something else that would work in there or if it was a standard item or something. I don't have a local dealer and hate to order small parts as I know the dealer hates to bother with it. Ideas what will work? Also what are the standard seal numbers for the rear? Thanks
Kenny
2006 EC300, 2000 XR650R, 2003 EC250, 2001 EC200 (OK, the last two are really my sons).
Old 02-04-2010, 07:24 PM
robszombie's Avatar
robszombie robszombie is offline
Just removed my rear bearings & have found the previous owner had destroyed the washer!!! Have ordered a genuine replacement from my local dealer. I'd say that might be the route to go down, however, I'd think that a washer/shim of the correct thickness should do the job just as well.
Old 02-16-2010, 02:27 PM
I just made a spacer, its supposed to be 2mm thick, mine was tad thicker, but it seems to be working.
rear wheel bearing shim spacer dimensions? mattlloyd50 Enduro Chassis & Body 17 07-24-2010 10:13 AM
Rear Wheel Bearing 2001 XC250 thomasbyrd Enduro Chassis & Body 0 10-04-2009 02:04 PM
roller bearing rear brake pedal mxdj2003 Enduro Product Announcements 25 12-16-2008 09:29 PM
MC65 rear wheel bearing change bergerhag Enduro Chassis & Body 0 03-12-2008 03:16 PM
Rear wheel bearing ? ktmguy23 Enduro Chassis & Body 1 03-22-2007 06:45 AM
