Old 01-08-2017, 01:51 PM
Adam500 Adam500 is offline
Default powervalve spacer clearance
I have a Christini AWD with 2015 300 engine and E start in it.
I wanted to try the power valve spacer. How wide are they?
It looks like it be very close to hitting the starter if it were spaced out more than a half inch or so.
Do they fit the newer engines with E start?
Thanks.
Old 01-08-2017, 08:31 PM
philm philm is offline
Thanks.
I don't believe that they fit the newer e start models. You might be able to get a thin one machined to fit but it might not make much of a difference.
Sent from my Moto G (4) using Tapatalk
2010 GasGas EC300 Nambo
Old 01-08-2017, 08:36 PM
You can always bump your ignition timing a few degrees for free. That will give you more bottom end and midrange. Listen for knock just in case but I have not had a problem with this on any of my bikes.
Old 01-10-2017, 02:58 AM
SpirosZ1000's Avatar
SpirosZ1000 SpirosZ1000 is offline
I have the spacer sold from motocrosscenter in my 2015 300 e start and it fits just fine.No problem with the starter at all.
Old 01-10-2017, 04:21 AM
john r b's Avatar
john r b john r b is offline
Spiros, the '15 has an adjustable PV Have you adjusted this first before installing the spacer?
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 01-13-2017, 11:25 PM
Yes I have adjusted the pv.I have turned the screw from 2 turns out (standard) to 2,5 turns out because I want a more aggressive throttle response (like my 06 300 had )
Apart from that the spacer will benefit you in low revs whatever setting you choose for the pv.
Old 04-13-2017, 07:47 PM
So the spacer from checkpoint offroad DOES fit the 2015 300 engine with the e start. BARLEY!!! But it does!
Noticed absolutely no difference in power at all.
Clearance with a smaller silencer celler Enduro Engine - 2 stroke 2 03-04-2013 09:36 AM
Valve Clearance (Tolerance) Quicky1980 Enduro Engine 4 stroke (including EFI & Exhaust) 7 02-15-2013 12:44 PM
Graphics Clearance Harry Enduro Chassis & Body 1 11-26-2012 09:29 PM
powervalve clearance jeffs2200 Enduro Engine - 2 stroke 13 08-31-2012 10:44 AM
