Old 06-11-2007, 01:16 PM
nhrider's Avatar
nhrider nhrider is offline
Default Wow!
Well, I need a new rear brake lever. The sucker is bent. Called up the shop and they wanted 134! Man that's a lot of many.
I wonder what it would cost to have some one build one...
Old 06-11-2007, 11:11 PM
SpeedyManiac's Avatar
Post an ad in the For Sale/Wanted forum. I got a brand new pedal from jeffd for $60 + shipping which is a hell of a lot more reasonable then $130+ for a new one from a dealer.
Old 06-11-2007, 11:45 PM
jeffd jeffd is offline
I would suggest heating the pedal and bending it back. How far is it bent. If you heat and cool aluminum it anneals it (softens) - if you bend it, it will work harden it and make it stiffer (and more brittle too). If it is bent alot and you try ot just bend it back without annealing it - it will typically break. The trick is to go through a heat/cool cycle (anneal), bend it a little (work hardens it back to original strength) and repeat.
Old 06-12-2007, 05:45 AM
JoshP's Avatar
JoshP JoshP is offline
Brake SNAKE!!!!!!! NHRider!
Yes I to did not listen to the wise riders telling me to use a brake snake. That was until I broke my pedal and spent the $134.00 + $7.00 for the stupid brake snake that saves me about $134.00 bucks each time I ride.
Old 06-12-2007, 06:36 AM
nhrider's Avatar
Thanks.
It is bent enough to rub on the clutch case.
I'll see what I can do this weekend with it.
Old 06-15-2007, 09:18 AM
John_B John_B is offline
What is this brake snake that you speak of???
John B.
'03 GasGas FSE 400
'97 Honda CR 250
'02 Honda VFR800
Old 06-15-2007, 09:58 AM
eff's Avatar
eff eff is offline
It's on eof these:
