Steering dampers
Im chasing some info on steering dampers so if you dont mind whats your favourite and what was it worth? At the moment my choice is scotts so if you have one you dont want then pm me
Thanks guys.
Does this rag smell like chloroform? |
i have a motorsportz damper on my 12 300 i like it works great
I have a scotts with the underbar setup. Used to work great on the 07 nbut in the end it started to get hard to turn the bike. Took it off the 07 and then put it on the 12 and it was crap.
I will be sending it off to get serviced very soon. Having said that I just did a very rutted , bulldusty, sandy, whooped out double fist size limestone rock strewn mallee enduro without the damper and the bike was absolutely awesome. The suspension is just about there me thinks Cheers Mark
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E |
And I have a motosportz on my 2010. Don't have much seat time on it but am happy with the time I do. Kelly was a pleasure to deal with as well. Haven't used any other brands so no comparison to make.
Scotts, because I like the high speed ckt function with the low speed damping dialed out. A quality top mount tower is a problem though. I picked up a second really nice slightly used Scotts with for a price I couldn't resist. Fastway unit is very nice with the same design philosophy, buying new that would be a top choice as well.
The WER, GPR, and Motosportz all have only a simple, single passive valve ckt. Despite what they say it is not the same. The Scotts and Fastway have an active valve that kicks in a lot more dampening under high bar rotation speed. |
Shark4465- can you post a pic of your motosportz setup? I'm curious to see where the collar is positioned in relation to the front of the gas tank.
2018 XC300 |
sure can i will say it is a tight fit
I have the top mount and I'm not happy at all with the fit of the collar. I'd like to see if the collar on the submount is any different.
2018 XC300 Last edited by thumperrider1; 06-29-2012 at 08:08 AM. |
On the '12, this will be an issue with any tower because the tower center has to be in the general position of the tank bolt. The pre '05 frames were like this too, in '05 they moved it and it was easier. The Scotts tower will perhaps be a little better because its center is closer to steering stem center, but thats why its weaker. My custom tower is just like the Motosportz, half over the bolt.
I have a scotts but would really like to try a fastway out.
Steve 16 Beta 350rr 04 KTM 525 sx/exc gone 03 KTM 625 sxc-rehab unit-did its job and now gone 03 GG 250 ec-gone 97 GG 250 ec Gone |
Steering dampers for 2010/2011s? | ScottyR | General Discussions & Announcements | 34 | 01-12-2012 11:32 AM |
Need resource for rubber clutch dampers | reiterrider | Enduro Engine - 2 stroke | 3 | 11-29-2011 12:59 PM |
Steering Dampers | roostafish | General Discussions & Announcements | 30 | 05-04-2009 07:23 PM |
