Old 10-04-2014, 05:03 AM
Default Valvoline max life atf
Just thought I'd spread the word. My 300 gearbox has groaned and snatched since I've owned the bike. I've got the cr250 clutch pack, filed my basket and hub, drilled holes and removed webbing but still have the noise. The only oil if found that stopped it was capable of stopping it was Elf HTX 740 (this is what monesta recommend in their 4rt gearboxes) but at ?25 a litre... No.
I've tried atf-f and dexron 3, with OK results. But I found in a store near me Valvoline Maxlife which is a dexron 6 at ?9.50 a litre. Slapped it in the gearbox and safe to say, I am astounded, no slip, groan or drag. And it has a lower viscosity than dexron 3 (29 instead of 35 CST) so works perfect as a very high performance (read the spec for dexron 6, 100,000 miles!!) fork oil too.
Just thought I would share my good experience!
2016 RM-Z450
Old 10-04-2014, 07:50 AM
celler celler is offline
Thanks for Sharing. My Primary GasGas has a Barnett Basket that eliminated the issue nut my other one still has some growl.
Old 10-04-2014, 01:17 PM
zeuszuki zeuszuki is offline
Thanks for sharing. I run Valvoline Racing 2S oil as well, you should try it :-)
Old 10-04-2014, 08:57 PM
I had good luck with the Valvoline max life synthetic ATF from Walmart. As I recall it was the multi use flavor that covered most US and European cars and trucks. The sell it in a gallon container and as I recall it was not too expensive.
Why We Ride - Mid-Life Crisis liv2day Pictures & Videos 2 08-01-2014 06:38 AM
HUSKY it short life! jaysktms All Other Bikes... 10 11-14-2012 08:49 PM
GasGas parts, 2nd life Loosenut General Discussions & Announcements 1 04-10-2009 06:48 PM
515 real life questions?? Cruiser General Discussions & Announcements 21 07-25-2008 12:31 PM
where have you been all my life.................. 450sx General Discussions & Announcements 3 05-01-2008 01:04 PM
