Old 03-15-2015, 10:29 AM
liamthom's Avatar
liamthom liamthom is offline
Default Carburetor
A plastic piece that attached my carb to the air boot broke and i have not been able to find it. It also looks like i have a short body (~75mm from mouth to mouth) airstrike and the plastic piece made it possible for the air boot to reach the carb.
In the picture i am pointing to the part i am talking about also the airboot should be around the smaller end. The part looks like it is made of pp and has a grove to lock into the lip of my carb. Any information on what it is where i can get it and what carb i have is useful.
Thanks
Old 03-15-2015, 11:17 AM
john r b's Avatar
john r b john r b is offline
Try Hall's first. good luck. I've heard of the piece before but never seen one. Is the carb a 36mm?
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 03-15-2015, 11:20 AM
liamthom's Avatar
if the number on top is the size than 38mm. as well the inside diameter of the outflow mouth is 38mm
Old 03-16-2015, 12:05 PM
I removed my read block spacer a while ago and had a big gap I mounted the card to the boot and warmed the boot with a hair dryer. When it was hot enough I used a tyre lever and pushed it on to the front and clamped it up.
It stretched in to place but if it's of the bike for a while it sometimes need the dryer on it
Hope this helps if you can't replace the plastic bit never had any issues with it or by doing this
03 ec300
honda cr500 94
Old 03-16-2015, 08:57 PM
liamthom's Avatar
Im going to talk to my dad about calling hall's first i rather find the piece then stretch the rubber, but it is good to hear that it is a working solution.
Old 03-17-2015, 01:59 PM
liamthom's Avatar
Apparently hall cycles has no idea what it is.
Old 03-18-2015, 02:53 PM
never seen one before to be honest.
03 ec300
honda cr500 94
Old 03-18-2015, 02:55 PM
liamthom's Avatar
Yeah, i don't blame you my dad called the gas gas importer yesterday and they are yet to get back to us.
Old 03-19-2015, 01:12 PM
liamthom's Avatar
Halls, gas gas importer, epic and JD have not heard of this part.
Edit: Epic found it
Old 03-19-2015, 02:00 PM
roverhybrids roverhybrids is offline
I have one of those on my 2011 gasgas ec200 38mm AS1 carb. I have 3 or 4 other gasgas carbs and none of them have this spacer.
Try to find a part number on yours.
Or you may have to measure it.
Then check this page:
http://www.jetsrus.com/mounting_flan...tml#offiintake
After looking some more the above link may just be rubber manifolds.
I think you should just do the hair dryer trick and eliminate the spacer
2011 GasGas ec300R
2011 GasGas ec200 Six Days
Lectron Carburetor Testing & Adjustment singletracker Pictures & Videos 4 01-12-2013 09:37 AM
balanced carburetor 300ec Enduro Intake/Carburetion - 2 stroke 12 02-21-2012 10:07 AM
