300ec power valve cover
Hi, just on the off chance, has anyone got a rear chain guide and bracket for my 2001 GasGas 300, I'm also looking for the 'larger' left hand power valve cover. I would also like to try a fly-wheel weight on it. Hoping there are second hand bits around.
Thanks Rob |
I have all those 2nd hand parts on my 2nd hand bike, but I'm busy riding it.
Chain guide bits aren't that expensive., I think my fw weight came from Go Fasters, just confirm what flywheel you have, I had to machine my weight a bit to fit a full fat euro one. |
I'm thinking what ever ignition came standard with the bike in 01. The wires come out at 2 o'clock on the ignition cover???? The bike feel much better with those bits on then??? And you consider selling those bits in the future?
Cheers |
I have 2 spacer left from the Last Order.
These are 10mm each and can be mounted together or just One. Send me a PM when you are interested.
4 strokes are only good for power generators |
Hi, PM sent.
Thanks |
Be careful just adding a spacer to the pv cover. On certain model years - the clearance between the "cooling fins" on the cover and the radiator hose is not sufficient. If you fall, the fins on the pv cover can slice open the radiator hose.
Jeff
Hi, yip I've noticed that the front PV cover bolt is right in line with the radiator hose, so much so that I'm not sure if I can even get a spacer in there. Do you know if there is a way around this as when you say "if you fall" it's more like "when I fall"............
Thanks for your input. Rob |
Hi Rob,
When you fall - you probably want to have one of these : EC radiator hose protector 001.jpg click on image above to see larger view. http://www.trialendurodirect.com/pro...ector_143.html Jeff
Thread Tools | |
Display Modes | |
LTR Power valve cover | skid jackson | Enduro Product Reviews | 22 | 09-04-2017 02:42 PM |
LTR power valve cover | Bailey28 | Enduro Engine - 2 stroke | 11 | 02-16-2011 04:23 AM |
power valve cover question | geoff g | Enduro Engine - 2 stroke | 1 | 07-27-2009 09:25 PM |
Adjustable power valve cover | SeanUK | Enduro Product Reviews | 11 | 07-11-2009 05:11 AM |
Help wanted power valve cover | lightning | United Kingdom | 0 | 03-13-2008 10:46 AM |
