broken stator plate
Hello ,my ec 300 lose spark ,and i found ,that my stator plate is broken ,where engages a pick up coil .Maybe the reason is hard vibrations form the engine ,but now i cant find stator plate like spare part ,everywhere the stator is a set(complect) with the plate .Where in europe i can buy a stator or only the plate ?http://www.electrostator.com/fr/200-...ld-hp-300.html i found one here for good money ,but is this original stator or replica ? Thank you guys !
electrex
co.uk |
This is the stator ,any ideas how to fix the broken piece ? |
You could try to get sonene to weld it, but I guess it is cast aluminium and perhaps not so easy to weld.
You could also try to glue it using epoxy. As it only holds the ignition pickup, the load on that piece is quite low. However, there are some vibrations that would try to tear it off. Sent fra min E5603 via Tapatalk
Yeah i think id go for the epoxy as well cheaper than a new stator if it fails then at least you tried the cheapest option 1st
If it was mine, I would fabricate a bracket from the slotted hole to support the pickup coil. Should be pretty easy to do.
2021 Beta 300RR 2014 Gasgas XC300R 2019 850 Pro RMK |
I just noticed something that looks like winding damage on your stator, circled in red. Sorry if you knew this, just didn't see mention of it.
Was something else in there when you pulled it apart? |
Was something else in there when you pulled it apart? Does the KTM 2k3 stator work in the GG? |
Thread Tools | |
Display Modes | |
Stator Plate | GGRider01 | "Wanted to Buy" & "Want To Trade" | 0 | 06-24-2016 01:40 PM |
WTB Stator Plate for K3 (Large Ignition) | Jim Cook | "Wanted to Buy" & "Want To Trade" | 2 | 05-20-2014 09:31 AM |
Broken Clavical | GMP | Injury & Recovery | 68 | 06-17-2009 07:09 AM |
broken clutch?? | Simon_R | Enduro Engine - 2 stroke | 2 | 07-23-2007 05:50 AM |
Broken Link | Dingo | Enduro Engine - 2 stroke | 3 | 07-07-2007 07:15 PM |
