Cant get easy start
All greetings
What could be the problem? I can not start a motorcycle with gas throttle shut off. To start it, I must give it powerfull kick with wide open throttle, When he is at idle, have good idly. Allso he starts rendomly fron first kick or from therd, or tens... I do not see dependence Please help |
I have the same issue with the *kicker*. Even after the Lectron carb and head mod.
I can?t quite find the rhyme or reason. The eStart fires up right away. |
Is the Fuel fresh/new?
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
In my case, half is fresh, the other half was sitting in a very hot garage for a few weeks.
My 2011 GG was always a quick starter under the same conditions. Last edited by AZRickD; 01-19-2019 at 11:57 AM. |
I've found stale fuel can severely inhibit starting ability. If I ride every weekend she tends to start 1 or 2 kicks. If I leave it weeks to months it can take some more effort.
Is your air filter somehow getting wet when washing? Any chance you're pulling some moisture into the engine when trying to start? I tend to roll the engine through a few cycles before I commit. Find top dead center and get some good compression under the foot, and give a nice firm full kick with the choke on, no throttle. If it doesn't fire I repeat. I don't keep the bike on choke for more than 10 seconds usually. |
The weird thing is, as stated above, sometimes starts in one or two kicks. Sometimes seven. Warm or cold.
Sometimes I give up and hit the eStart and it *always* starts. Warm or cold. |
I'd check float level and clean pilot jet but also the choke hole into the throat. Also while you are at it the sparkplug cap swap out and see if it gets better should be circa 5k resistance.
Reading what I wrote above my cold starting got instantly better when I put newer carb on. I bet the choke feed hole was blocked. Never worried about it as once warm was never a problem.
And now i remembering - i never use fool throttle while first start, only choke, so mayby i should fire ewery time with choke, even on fully warm engine ? |
Ahh warm engine different story.
Clutch drag! Many have a little drag which makes starting in gear a bit more sensitive than in neutral. And hot starting.. Many 4 strokes offer a hot start lever - allows air into the carb to help hot starting. The simple work around on a 2T is to open the throttle a bit. I can't remember last time I started the bike once warm without a bit of throttle. If I've laid it over and flooded it then it gets wide open throttle and a few good kicks. |
Thread Tools | |
Display Modes | |
Why No-Toil is an easy choice | desertgasser300 | Pictures & Videos | 12 | 02-18-2014 07:31 AM |
The Pro's Make It Look So Easy | Rick | Pictures & Videos | 1 | 12-04-2011 10:49 PM |
Is it easy to jet your own carb????? | GasGas.ec300.Andy | Enduro Intake/Carburetion - 2 stroke | 2 | 01-13-2009 04:05 PM |
I thought two strokes were easy to start??? | sammyj18 | Enduro Engine - 2 stroke | 14 | 04-15-2008 05:23 AM |
Easy question | FFRDave | Enduro Engine - 2 stroke | 3 | 08-27-2006 07:36 AM |
