Q: Stainless front brake line?
Is there a Stainless braded steel brake line available for
the GasGas EC-XC line of bikes? I am looking for one for the newer Nissin caliper equipped models. From around 2000-2003. If not, is the OEM small diameter teflon/plastic line just as good for overall feel and stopping power? From my research, I believe the front brake line from the CR250R should work. Is this true? Thanks for your insight. Jeff |
does anyone else know the answer to this? As I am also up for a new front brake line (07 EC300)
thanks
2007 Gas Gas EC300 2005 CRF450X 2006 WR290F Wandas Bike 2007 CRF280X Rebeccas Bike |
Well, I took the chance and ordered a Russell Steel braided front
brake line for a 2004-2006 CR250R. It fit just fine on my project XL350SMR Super Moto bike. I used the Nissin front brake caliper and master cylinder from a 2002 GasGas 300. I needed the new caliper to fit it to the EBC 320mm rotor and new carrier bracket. As the old honda caliper would not fit the new carrier bracket. It is just a tad short though. It could use maybe another inch or so, but, it works without binding as the brake line passes over the speedometer cluster.. I'll follow up with a few pictures in a week or so. Good luck, Jeff |
Just an FYI - Les at LT-Racing has a bunch of steel braid front brake lines for the gasgas.
jeff |
hmmmm.. I guess that was the kind of information
I was looking for back on Sept 26th when I placed my first post. Good to know for future reference. Thanks, Jeff |
You should be able to get them directly from GasGas if you want. The ISDE and racing edition bikes comes stock with braided steel brake and clutch lines.
Thread Tools | |
Display Modes | |
rear brake line issue | skid jackson | Enduro Engine - 2 stroke | 1 | 08-16-2009 09:05 PM |
Front brake line? | nick790 | Enduro Chassis & Body | 0 | 05-27-2009 03:50 AM |
ec250 '02 brake line crossover | thensome | Enduro Chassis & Body | 2 | 08-17-2008 12:41 PM |
Rear brake line crossover? | ScottyR | General Discussions & Announcements | 2 | 07-04-2007 06:17 AM |
