clutch bleeding woes
having installed a new clutch in my bike, i went to bleed the clutch but found it was not bleeding at all.
So i took it off the slave cylinder and blew some air in it to pop out the piston, everything looked fine so cleaned it up and pushed the piston back in and tried to bleed the system once again but I cant seem to get any fluid through the slave cylinder. any ideas?? |
Yes, it can be a b*tch. When I put on my rekluse I had problems. I finally had a KTM tech help me bleed it. He just keep bleeding until the lever firmed up. I'll try to find my thread and post it.
Here is the link, ignore all my whining and go to post 23 by GMP. GMP knows his stuff. Also see post 39. http://www.gasgasrider.org/forum/sho...h+bleed&page=3
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar Last edited by Moto7man; 08-12-2014 at 02:57 PM. Reason: Add post |
Bleed it backwards with a large syringe first then bleed normally.
if not i bled my clutch last weekend and I had to cover the clutch fluid reservoir with a towel for it to bleed... God knows why perhaps covering it while pumping the lever stopped some air getting in ?? |
As with the front brake, you have to pull the lever in a few mm to open the "bleed" port.
It is a built in mechanism to prevent air getting in the system when you flip the bike over. |
Maybe that is why I had a problem. Thanks for the post.
Bleeding clutch! | Pepperami | Enduro Engine - 2 stroke | 14 | 09-22-2013 03:19 PM |
Clutch bleeding - how to | swazi_matt | Enduro Engine - 2 stroke | 2 | 08-09-2011 02:57 AM |
Bleeding hydraulic clutch...new line | blanc | General Discussions & Announcements | 7 | 04-12-2011 03:56 PM |
water pump woes | skid jackson | Enduro Engine - 2 stroke | 0 | 05-16-2009 02:19 PM |
HELP! - bleeding hydraulic clutch | SpeedyManiac | Enduro Engine - 2 stroke | 6 | 10-10-2008 07:12 AM |
