extreme heat?
i race in a local hare-scramble series here in Georgia and most races are in the summer. during the last 2 events the temperature has been approaching 100degrees. and i have noticed that the seat on my xc300 gets hot enough to cook my jewels. the last lap i had to alter my riding style towards the back of the seat to stop from ruining any future family plans that i might have. has anyone else noticed this about a gas gas i am considering installing some type of heat barrier to cut down on this? this problem only is happening on the forward part of my seat that goes over the fuel tank.
If the front part of the seat is getting that hot, are you boiling your gas too?
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
What you feel is probably the hot air from the radiators, combined with friction from moving on the seat. There is no way the seat can get hot enough to be uncomfortable from engine heat. The fuel tank and airbox form very large insulators. If you don't do it now, try the Moose undershorts (like lycra bicycle shorts) and some butt grease. Its gross, but works!
For a real nut roasting experience, you should try a Cannondale 440 (with rear exhaust and underseat header) in mid summer. |
i don't seem to be boiling fuel and there is a noticable difference in temp between the front and rear of my seat
Just wondering if you might add a little more insulation between yourself and the seat. Are you wearing bicycling shorts underneath your riding pants? FYI - I also like riding with jockey "workout" underwear. They are 100% cotton.
jeff |
Being largly a sit-down rider, I too have noticed my "cockles" getting a bit warmer than usual during the summer months. (I've since switched to riding in baggy basketball shorts.) I take it, the airflow via the radiators is the culprit.
Maybe there's a better way to redirect the radiators' exhausted airflow using adhesive-backed insulation tile like the stuff Moose makes? Or better yet... Les could come up with a sweet fix using the same plastic he uses for his engine mud guards. Alternately, I've never have had a problem with boilovers or loss of power due to engine overheating. TP '03 EC 300 |
VORC Extreme Sprint -Australia | Keg | Ride Reports | 0 | 09-12-2010 07:35 PM |
Canada's first Extreme Enduro: Xtinction | SpeedyManiac | Pictures & Videos | 6 | 08-29-2010 05:55 AM |
Valley HS July 18, Jack Pine July 25 - Sweet in the Heat | twowheels | Mid-West Forum | 3 | 08-06-2010 11:37 PM |
hot start extreme difficulty | noobi | Enduro Intake/Carburetion - 2 stroke | 15 | 07-15-2009 05:06 AM |
Top end break in, heat cycling | rpduc | Enduro Engine - 2 stroke | 9 | 05-04-2009 11:55 AM |
