Shroud wrecking report
Just went for a quick blat around my cuz place and managed to weave through a few trees and rip off the right hand shroud.
All good you might say, just pop it back in. Not so.... The sapling managed to pull the shroud then also snap the shroud in two. The shroud is very pretty in its two piece structure but as the top part is only held to the bottom part by three tiny tabs , guess what breaks? I will need to now drill three small holes in each shroud and cable tie them together, Shouldnt look too bad but just a pain in the butt. Anyway, just thought I would share Cheers Mark
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E |
Same thing happened to my brother falling over in a field.................
2018 EC 300 |
Headlight is being sorted now hopefully.
Shrouds look great but seriously guys.... three tiny tabs? Cheers Mark
Mark,
Sit tight, I designed a fix and have the parts to try on my bike when it shows up. It will be done before I ride it and I'll post the info. I saw this one comming. They could have acheived the same look with a conventional mounting design. |
Honda is making their pretty 2013 shrouds by molding the red and white simultaneously!
Why not just keep things simple and functional, it can still look good. Husky did this two part/tab thing years ago and keeping plastic on the bikes in the woods has been a nightmare.
Basically what I have to fix it is posts like the rad braces I designed years ago that Les sold. These mount the rad and slip through the grommets, and can be used with or without rad guards or frames. The goofy inserts that pop into the rad grommets are completely removed from the shroud. I have these really cool M6 standoffs with a U joint in the center. These will thread into the end of the posts. The other end will provide a bolt on shroud mount through M6 holes drilled in the shrouds, and the joint will accomadate the angle of the shroud. Should work good, I should just have to adjust lengths to get everything to fit with the same width. The upper/lower connection I might just cut everything off the back and plate it together from the rear, but I'll wait and see if the solid lower part mount is enough. I have some nice stainless M6 button heads that don't look bad at all. I don't want to deal with zip tying a new bike back together in the woods, a few extra bolts through the plastic does not bother me. |
Gas tank shroud | lineman12345678 | Enduro Chassis & Body | 2 | 03-01-2010 03:47 PM |
Shroud template | reeve | Enduro Chassis & Body | 0 | 09-23-2008 03:24 AM |
Shroud / tank repair | Brian VT | Enduro Chassis & Body | 1 | 07-05-2008 02:31 PM |
