'06 EC300 ajs front wheel spacers
Where can I get replacements? Mine have serious grooves worn in from the bearing seals, but I can't find any reference for replacement parts.
If you have a 20mm front axle, then these are probably the part numbers:
BC250018018 BC250018019 (these were correct for my AJP hub with 20mm axle). I got mine from Greenland MX, but any GG parts place should be able to get them. http://www.greenlandmx.com/gas-gas-f...d-p-1-51-4712/ |
Thanks! I'll look for a parts house here in the US.
Where are you located?
Gofasters is in Minnesota and Gasserparts is in West Virginia for a parts source.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
What forks do you have?
checkpointoff-road.com is the shizz.
So the listing shows part #BC250418019 and Qty (2) for front wheel "bushings". My axle is 24.8 mm (as close as I can measure). Can anyone confirm that these are the parts that the front wheel seals seal against, and that 2004 will fit my 2006? |
http://www.gasgasmotos.es/en/manuals/3.html Go to the exploded listing of the correct year. I hope this helps.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 Last edited by nknudsen; 04-11-2013 at 09:44 AM. Reason: Missed exploded direction |
Anyway, yes the part number BC250418019 is correct. |
Front wheel spacers. | iamyvr | Enduro Chassis & Body | 4 | 02-22-2013 10:09 PM |
Wheel bearing spacers | nato | Enduro Chassis & Body | 1 | 01-20-2013 10:39 PM |
Wheel spacers. | Ud_luz | General Discussions & Announcements | 15 | 07-10-2012 11:16 PM |
replacement front wheel for ec300 | mk1jt | Enduro Chassis & Body | 3 | 02-17-2010 07:59 AM |
99 ec300 front wheel bearings and seals | barbwire44 | Enduro Chassis & Body | 3 | 04-01-2009 03:51 PM |
