45 Marzocchi Spring Crossover
Hi Guy's If possible can anybody tell me if there is a direct crossover for the 45mm marzocchi springs, or even what the dimensions of the springs are so that I can do some searching without stripping my bike. I have a EC 2007 2007 and the standard set up is not quite enough and getting springs here in sa for gas gas is not the easiest, so if there is a direct crossover it will really help Im sure the length can be adjusted with the spacer as long as the outer and inner diameter are close many thanks in advance Gary
03 Suzuki RM 250
Dont follow me, You wont make it. |
If its for the Shivers i put Husky spec springs (Racetechs and heavier rates) in mine as i couldnt get the GG ones in time. They are slightly longer than the stock ones but worked fine
45 marzocchi question | motodave63 | Enduro Suspension | 6 | 04-30-2009 08:31 AM |
Marzocchi parts HELP PLEASE | adickted | General Discussions & Announcements | 3 | 04-01-2009 01:38 PM |
Marzocchi-Now U.S. owned. | gasgasman | General Discussions & Announcements | 11 | 09-02-2008 07:25 PM |
Selector spring crossover? | scrambler250 | Enduro Engine - 2 stroke | 4 | 09-21-2007 09:57 PM |
