Old 10-18-2010, 07:59 PM
Bradz Bradz is offline
Default 2010 EC300 Rear Brake Master
Does anyone know what model bike the 2010 uses for the rear brake master cylinder, I am aware the caliper has changed to a Yamaha/Kawasaki pad, I have taken the piston/seal part to an aftermarket parts distributor and they were unable to cross reference it with any of their stock. GG here in NZ tell me I have to purchase a complete assembly at $350, furthermore they dont have it in stock..Any information would be appreciated..
2010 EC 300 and counting
Old 10-18-2010, 11:17 PM
gg3's Avatar
gg3 gg3 is offline
Hi Bradz,is there a part failure I should be aware of?Mines had no problems so far.
Old 10-19-2010, 10:49 AM
at this stage, i have taken the parts to a seal maker to have custom made, hopefully before the weekend, at a cost of $50. Im hoping its not an everyday occurrence, there is only 40hours on the bike, I lost all braking on my last ride out, tried bleeding them and only dribbles came out the nipple, no significant pressure at all, thus determining a pump problem. I replaced the pads, the caliper moves freely until point of where it should grip the disk, but with no great pressure.
Old 10-19-2010, 11:29 AM
bchatt's Avatar
bchatt bchatt is offline
Bronze Level Site Supporter
IMHO, GG NZ (Triumph) are a disgrace. If they are not prepared to properly support the bikes they import, they shouldn't be selling them.
Did you try Scotties, or kegs outfit (can't remember the name,sorry) in AUS, or Go Fasters?
Is the seal actually visibly damaged? Sounds kind of weird. Not wishing to dis your efforts, but did you bleed the hell out of thing for several evenings in a row? I only ask because what you describe sounds like a normal air bubble kind of problem. How come you replaced the pads at 40 hrs? were they stuffed in that time? that sounds kind of weird too...
Barry
07 EC250
Old 10-19-2010, 12:22 PM
Visually the seal didnt have any major marks, however the memory wasnt so great, so thinking if they had become overly soft the pressure may not hold correctly???.
I have back bleed them twice, conventionally a few times, you name it ive tried it, cleaned the caliper which looked good, the pump is the only part in my mind which can be causing the problem of not pressurising as there is no visible fluid leaks. As for the pads, they dont last long in wet pumice dirt..
Old 10-19-2010, 12:30 PM
They are a bitch to bleed, I'm willing to bet its fine. Conventional and back bleeding doesn't work well. What works is taping the bleeder nipple threads with teflon tape for a good seal, and applying a hard vacuum on the bleeder with a syringe/tube and rapidly crack it open/closed. Its the only thing that worked for me.
Old 10-20-2010, 12:00 AM
gg3's Avatar
gg3 gg3 is offline
Wink
I have heard similar about Triumph.It's hard for a smaller brand to get sales traction without excellent support.Although I did have a claim on a seat rip,where the cover folds under over the plastic edge,it was quite rough & wore through at 12hrs.I got it recovered & they picked up the bill.I think it may have been more the persistence of the local dealer that helped.
As for the pads,grown up bikes (300's) take a bit more stopping than those teenage crutch rockets
Old 10-28-2010, 08:52 PM
WTEC's Avatar
WTEC WTEC is offline
I used a Suzuki RM250 rear master rebuild kit in my 07, was a perfect fit. I think most, if not all later model Japanese 250 2-strokes used the same Nissin rear master. My 2010 looks identical from the outside, I'd be willing to bet the internals are the same.
Wes.
13 EC200 Race
10 EC250 Six Days (SOLD)
07 EC250 (for sale)
85 RZ500
75 XL250
71 CB100
08 DRZ70 (son's)
Brake and Clutch master cap crossover Leo Enduro Chassis & Body 2 02-10-2010 01:56 PM
Rear brake clevis Fred1956 Enduro Chassis & Body 12 01-24-2010 02:51 AM
Rear brake master cylinder crossover? bergerhag Enduro Chassis & Body 5 04-09-2009 09:26 AM
Anyone no if any other MX bikes that have the same rear brake hose as my 2001 ec300 GasGas.ec300.Andy Enduro Chassis & Body 3 02-28-2009 07:11 PM
