suspension gurus
I am getting my suspension dialed in & have the shock sorted.But I am crap at interpreting fork feed back so need you guys to tell me what to adjust for this behavior- sits up nice through whoops & choppy stuff,handles roots & rocks nice but through berms/rutted corners it enters nice but then want to run wide or climb out of the berm?It really is fine tuning as it generally works great.Correct springs & sag have been done.Any suggestions welcome except get fit or eat healthy.
Incorrect mid stroke valving can produce the symptoms you described.
Rear sag maybe too soft, also. |
Sounds like a geometry issue rather than springs/ valving. Before going back inside the forks, you might try sliding the forks up in the clamps to the next "ring" (lowering the front of the bike.) What is your rear sag? Raising the forks will have a similar affect as running less sag in the rear.
Thanks Guys,that makes sense with the geometry.I don't want to make it unstable on open stuff like my KTM ride mates,it is really stable at speed .
Sag figures- 34mm & 120mm It is a 2014 model so how do those figures look?I have my forks 5mm through the clamps at the moment.I assumed the sag is correct as I had a shop set it up to my weight.Should know better. |
Valving is speed sensitive, so to say mid stroke valving is kind of void. Spring can play a huge influence deeper in the stroke though.
Work with your rebound a bit before you get too carried away gg3. Slow it down a few clicks (close the clicker) and see if it improves. Sometimes if its rebounding too fast it won't 'settle' mid corner and will try to stand up or run wide. Same goes for climbing out of ruts. If you slow it too much it'll pack down in the whoops and trail trash so always a compromise. Often a click or two is all it takes once you're in the working zone. |
That is exactly what it is doing in corners.Also occasionally I hit a whoop & do a 'bounce' wheely-too fast front rebound? Feels pretty cool when you power on & hold the wheely though.
How do these Sag figures look? - 34mm & 120mm |
Way too much rear sag. Choppers out the front.
Definitely start by reduce/slow front rebound(bottom of fork clicker).screw in 2 or 3 clicks at a time and ride over same bump,same speed so you can feel the difference. Or stand on pegs and bounce bike,pay attention to which end rebounds faster and try and get them balanced roughly with the clickers.you can add rear rebound also but too much and the rear will 'kick' off logs and square edges.once you get rebound close finetune with compression.based on that sag you may well benefit from a stiffer spring or increasing the preload a turn or two.
FWIW heres my 13 with ohlins 88 shock,zokes 48,me 75kg on the bounce test(stock)front was down and back up the stroke noticeably quicker than rear. front rebound 13 from full in(stock 20)7 slower rear rebound 21 from full in(24)3 faster front compress 16 from full in(14)2 faster/softer rear compress 13 from full in(15)2 slower/firmer pfp 1/2 turn in from full out,less preload! (stock 2 turns in from full out) race 97mm/static 39mm(im bordering on light for this spring i think) bike used to kick front up over jumps and try and wheelie hillclimbs too,now its much more balanced.also way less tiring on the arms!initially i liked the shock action but found the fork too firm/harsh so concentrated on fork,slowing rebound/softening comp,reducing preload(external pfp).eventually found i had too stiffen comp,quicken rebound,tighten sag on shock also to get to where im happy enough.next step fork would be internal tweaking of rebound and less seal stiction,maybe less preload
2013 ec200r |
Shimming Brainteaser for the susp-gurus | swazi_matt | Enduro Suspension | 12 | 09-18-2017 08:15 AM |
For all you jetting gurus out there | mou636 | Enduro Intake/Carburetion - 2 stroke | 2 | 02-20-2015 03:33 AM |
Suspension gurus please help | stemplin | Enduro Suspension | 10 | 12-09-2011 02:33 PM |
ECU gurus??? | BigChina | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 05-20-2011 11:40 AM |
Need some help from the jetting gurus | MattR | Enduro Intake/Carburetion - 2 stroke | 7 | 01-29-2008 01:55 PM |
