Led front headlight goes off when revved
Ive wired up a new led bulb directly to the reg/rec it powers on when idling with a slight flicker, but when the engine is put under load it goes out.
What have i wired up wrong |
Try put a large capacitor as a faux battery, say 1000uf or ideally more and 25v rated. Or hook up to a battery to check. Regulation can go screwy if it sees an open.
Thanks for the reply
In short the 2 wires from external genetator are wired directly into a new Reg/Rec , and the headlight wired up directly to R/R (no switches wired in yet) so where do i put the capacitor? |
www.endurohp.eng.br Sherco ST300 2015 (Trials) https://www.instagram.com/leocm74/ Brasil! |
So that would be on the actual wire for the bulb +
correct? Is a bigger uf capacitor better ? 2000/ 4000/ 10,000 buyong one is no problem just want to by the right one the 1st time |
2200uf 25v will be fine, and what I've used in similar setups.. A 16v will be too close to the line but would be OK for a test. They will be polarised so + to + power.
FOR SALE, 250XC forks, NEW fender, front wheel, front wheel bearings | iamyvr | Parts | 5 | 07-27-2014 08:18 AM |
2011 Front Fender with 2010 Headlight | Jakobi | Enduro Chassis & Body | 4 | 05-24-2013 11:55 AM |
lights flickering and going off when revved | Elliker | Enduro Engine - 2 stroke | 9 | 01-21-2009 05:28 PM |
06 EC300 - strange sound when over revved | colinmc400 | Enduro Intake/Carburetion - 2 stroke | 5 | 05-02-2008 12:10 PM |
