Rear Brake Cooling Fins
I have a bad habit of riding my rear brake too much and it has been overheating. I'm trying to change my riding style, but I also added some cooling fins that seem to help delay rear brake fade. The fin is a really a single piece of 1/8" x 1.5" aluminum bent into a "U" shape and JB-Welded to the rear brake caliper. The JB Weld is a metalized epoxy and the heat conducts well across the glue joint. It definitely keeps the rear brake cooler.
Steve |
Steve |
I epoxied on a small one inch by one inch heat sink from radio shack.. can get them for like 5-6 bucks glue it on just like you did with the u shape piece and you'll never overheat the brakes again..
Steve 16 Beta 350rr 04 KTM 525 sx/exc gone 03 KTM 625 sxc-rehab unit-did its job and now gone 03 GG 250 ec-gone 97 GG 250 ec Gone |
Solid rotor with organic pads, no problems even in south Jersey, with a lot of tail dragging around tight trees. Sintered pads conduct a lot of heat back to the caliper.
Steve |
oil in cooling water | Klausen | Enduro Engine - 2 stroke | 10 | 08-06-2011 09:35 PM |
Rear brake position | Lildawg | Enduro Chassis & Body | 18 | 06-15-2011 11:17 PM |
FSE 450 rear brake... | Vinny | Enduro Chassis & Body | 4 | 06-09-2011 07:52 PM |
rear brake reservoir | oilman | Enduro Chassis & Body | 4 | 06-06-2011 12:10 PM |
cooling pump shaft | lufc | Enduro Engine - 2 stroke | 11 | 05-25-2007 05:42 PM |
