Slider question
I have a Gas gas Wild 300 two stroke. I just bought the bike and the bottom end need some cleaning up and it loads up. I'm at 5200 feet. The carb is jetted
Main 150 pilot 40 ...1/2 a turn out needle in the top position n1ef is the needle number slide is a #6 I have a #9 slide. What does the slide numbers mean and whats the difference between a #6 and a #9? Does anybody have a start point on what I should start with? It also came with another needle #CHN
2004 Gas Gas Wild 300 ITP beads all around |
Check the jetting thread with the chart. You motor is the same as the EC300 so look for similar situations. Jetting is alway talked about on here.
Go to the bottom of this article for throttle slide (cutaway).
http://www.superhunky.com/feb01rsVintageMikuniTech.html Here's a direct link to the current jetting database. http://www.gasgasrider.org/gallery/d..._22feb2008.jpg |
You're running a 150 MJ. WHOA!!!!
A 150 MJ would cook both my EC300s in minutes at 5200. I run a 165 to 168 at a 6000 ft ASL base in Idaho.
There is also a very big difference between a #6 and #9 slide, with #9 being a lot leaner (#6,#7,#8, #9, rich to lean). I could be wrong, but I would think that with the Quad being a lot more load on the motor than the bike, you would want to be richer for the same conditions if anything.
Check the float height before any jetting sessions. |
Thanks for the info guys,
Chain slider question. Please help | joey11 | Enduro Chassis & Body | 3 | 12-05-2008 06:43 AM |
chain slider / chain guide crossover? | bondo | General Discussions & Announcements | 1 | 09-01-2008 09:13 PM |
