Tools/parts to service bottom end
What 'special' tools do I need to split the cases and service the bottom end of the engine.
I've done a KTM200 before and think I got away with holding the wheel on the brake to undo the nuts I needed. Now I have spare clutch plates so I could make up a tool (long bar bolted to clutch plates) to hold the clutch basket. Is that everything I need? What gaskets do I need ( will pre-order them) and what would you replace as matter of course while the cases are apart - I don't want to replace every bearing if I don't have to (or would that be a better idea?) Should I invest in an airgun, will that help a lot? Any other tips including what to undo/strip while the bike is still in the frame would be welcome. I may even write a guide if I'm feeling nice since I can't find one already.
'05 Gas Gas 300 '97 Aprilia Pegaso 650 '99 KTM 200 '95 ish XR630 (died many times in Oz) |
good luck. |
loose bottom marzocchi cap | noobi | Enduro Suspension | 2 | 06-06-2010 07:48 PM |
Ohlins service parts. | widebear | Enduro Suspension | 5 | 01-08-2010 04:29 PM |
Ec200 Bottom end. | goody | Enduro Engine - 2 stroke | 0 | 02-13-2008 03:03 AM |
