We are stumped a little ??
OK here goes, I have a 08 300 EC with LTR jetting kit.It runs good ,has decent bottom and a strong mid range hit . My son just picked up a 06 300 DE that was a repo out of New Hampshire. It has a little time on it and appears to be stock but when we finally got it all checked over and fired it up we were very surprised at the power delivery . THIS BIKE IS AN ANIMAL!!!! The first thing that I thought was that it had the RB carb and head mod but we looked through the carburator and can't see any divider plate . It has the stock 06 pipe. The needle is bronz colored and the number has been ground off. We are stumped and would love to get the 08 to run this good. Did GG change the port timing from 06 to 08 ?? Could the 06 have a different CDI box ?? All we know is the 06 builds loads of arm stretching torque right off the bottom and keeps right on pullin through the mid range and upper end. Has anyone ever played with the governor spring on the power valve ?? Any suggestions would be greatly appreciated.
Is the '08 a full "EC" with the 2K3 ignition? The DE has the 2K2.
Check to see what locations the wires leave the ignition cover. If at 10:00 then 2K2, if at 2:00 then 2K3.
2004 GasGas DE250 |
The 08 and the 06 has the 2k2 ignition. The only obvious difference is the 08 has the FMF pipe and the 06 pipe has GasGas stamped on the side of it.
I have used the FMF, Doma and stock GG pipes. The FMF pipe signs off very early. The Doma on my '01 XC300 and the stock GG pipe on my '06 EC300 are nearly identical. The stock GG pipe and Doma are much smoother and have much more top end power than the FMF. My real world dyno is a hill. On a steep dirt hill, my '01 XC300 with the FMF was only able to pull 3rd gear at a moderately high RPM. When I put on the Doma pipe, I could pull 4th gear screaming at a much higher RPM than with the FMF pipe in 3rd gear. It was a huge difference. The Doma & stock GG pipe are much better than the FMF Gnarly for my woods trail riding and open sand riding. Try swapping pipes and see what happens.
The RB designs head work will make a big difference on the low end torque. It also improves fuel efficiency.
The RB designs carb mod works well to clean up the partial (0 to 1/2) throttle operation. After you test the RB designs mods, try swapping the pipes and see how that affects performance. I expect that the pipe swap will make the biggest difference on the top end.
3 things that may be different
Jetting - sounds like an LTR needle in the '06 Ignition Compression I say, if it is an animal just off idle, you have a higher compression head on the '06. It's an easy swap to test it out on the '08 sometime. The resom I say this is that my '05 was whimpy off idle compared to my '00 with the higher compression head. With the RB cut head, the '05 became an animal that I tamed with different jetting a gearing.
Mike Baxter 2005 GasGas EC300 (Ohlins front and rear) 2007 Yamaha FZ1 2003 Pampera 280(hers) |
