Adding keyed ignition 06 ec300
Hi all, I have an 06 ec 300 in beautiful shape. I'd like to add a keyed ignition to it.
I purchased an ignition from Motocrosscenter.com, it has 3 male space terminals on it. I figured I'd just wire it in parallel with the killswitch, hoping to keep the killswitch as well. Looking for a little help to make sure I do it properly. 🤷*♂️ |
Simple enough. Take a multimeter to the switch terminals in the OFF position. Find two that have continuity and check that they go "open" when the switch is ON.
Also check for continuity to the switch housing since if it is attached to the bike frame, it will become grounded. Switch terminals generally do not have continuity to the housing. The "closed" terminals in OFF get wired accross the kill button.
2011 EC250E |
I've seen a few of your posts on ADV Rider. I only ride single track in Simcoe since the Ganaraska forest became a disaster area.
2011 EC250E |
You would need to connect it in series with your kill switch
sorry, Im in correct
Ignition Lock EC300 07 | stian | Enduro Electrical & Wiring | 5 | 05-02-2023 12:57 PM |
Need a new keyed ignition switch. Help! | fst96se | Enduro Electrical & Wiring | 3 | 11-18-2019 09:07 PM |
Can someone help me with a adding a headlight to a 99 EC300? Need electrical help. | flatout111 | Enduro Electrical & Wiring | 6 | 11-28-2012 09:38 AM |
ec300 ignition cover | RiverRight | Enduro Chassis & Body | 2 | 08-17-2012 05:01 AM |
EC300 -2011 ignition timing | FinGas | Enduro Electrical & Wiring | 9 | 04-10-2012 06:30 AM |
