Calming down the EC300
Has anyone ever used or use the G2 cam system in on their 300`s? I live in the PNW and out trails are really slick and snotty in the winter. I am looking to calm the hit down without having to use a fly wheel weight, head mod etc.
Marc
15 Beta 300RR Race Sold KTM 450EXC now moving over to RED! Looks like I found the right bike. Thanks REVERUP! 2011 GasGas EC300 "Stolen By A Scum Bag" 2009 450EXC Sold to Rapid Dog EURO Factory Anti-Hop slipper clutch, GPR V4, Akropovic Full Ti Exhaust, 2013 suspension and wheels. 2009 300XC 2005 525 MXC 2000 WR 400 1996 XR 600 1987 CR500 1990 KX500 |
you can get a adjustable power valve called trusty, that should do it but its a bit pricy
http://www.trialendurodirect.com/pro...Cover_139.html
03 ec300 honda cr500 94 |
I have used one in the past. Definitely makes the beginning of the Throttle progressive. I have found that I would eventually return to the sock cam. For me I find I tend modulate traction though gear selection and clutch. I tend not to have issues with throttle control. So I would say good product for the right person. For me I'm actually looking at their quick turn model so I do not have to change my wrist position so much. I have noticed that I prefer the shorter pull of my KTM that has a 36mm carb vs the 38mm on the GasGas.
Now for a second answer. If you are looking for very precise control below where the power valve opens the G2 will work really good for this. Where I now live there is enough rock that it never really gets that slick. When I think slick like this, I thing wet hard clay like one would fine in a river bottom in IOWA - Grease Just recenty I added a 1mm shim to the power valve and it seems to have helped make it smoother |
I put a 1mm thick shim in the governor mechanism by bulling the side cover, removing the governor, and putting in the shim. Takes some work. What is interesting before I did this I was richening the needle to get the power smoother when the power valve opens. With the shim I had to drop the needle a clip and it may still be too rich. Just to be clear the shim is not magic. I was just working on trying to make it smoother when it cam on the power valve.
I am looking for a 4T type roll on. The trails here in the winter are filled with off camber roots and rocks that are really slick. I find myself taking tree samples more than I like
How are you shimming the PV ?
NEDJ, NEDW needle is very smooth.
2011 EC300 Six Days 2010 EC300 Nambotin Replica |
It has the NEDJ needle now. The jetting is spot on! Maybe to much
What about rekluse and lug a gear high.
calming the hit down.... | stainlesscycle | Enduro Intake/Carburetion - 2 stroke | 13 | 04-10-2011 06:05 PM |
2005 EC300 vs 2007 EC300 | alecsstefan | Enduro Engine - 2 stroke | 19 | 01-22-2010 01:40 AM |
