ec 300 sudden power loss, wont rev
Ok, I have read lots of threads on this but still puzzled. I was on a very bumpy section with lots of loose rocks, I had the throttle pinned going up the gears, the bike was riding it well, I could hear the rocks battering the little gasser but I was having fun. I slowed down to turn onto wet muddy grass and opened her up again, nothing, she was totally flat, no power band. I immediately thought i had crushed the pipe so I stopped to check. It was fine. I have now checked the following
Stripped and cleaned the carb, twice. New plug. Removed pv cover and checked for operation. Ok Checked silencer for blockage. Checked base gasket for leaks. Checked reeds. Checked carb to inlet rubber for perishing and holes Rode it with ckoke on and off. Rode it with fuel switched off (till it stopped) It had new crankcase seals not long ago and oil level is fine Fuel and oil ratio is as always. Checked connection to cdi and coil. When I hold it wot on the road, it gets to certain revs and acts like its stroking, it sometimes tries to go if I wind back the throttle. I am close to trying a match in the petrol tank, it wont fix it but it will make me feel better. Can anybody help, please. |
Check for a broken reed?
Sent from my iPad using Tapatalk |
"Maybe" check the pin that holds the connecting spring to the PV actuator plate has not broken off. Behind cover on R/H side of the cylinder. I just had this problem myself and that's what I found. It was still working to a degree but the exhaust valve was not opening enough when on the gas.
I have checked reeds, they are ok.
faulty cdi?check insulation on ht lead for chafing?
2013 ec200r |
Sounds exactly the same as when the pin on my power valve actuator snapped off
Just checked the power valve again, looks fine to me. There is a steel wire coming up from engine that moves the pv. This is connected via a locknut, then there is central bolt holding plate to pv spindle. Should there be anything else. It moves to full open as soon as you crack the throttle. Then bounces back when I let off.
Sent from my iPhone using Tapatalk |
Time for a compression test. This doesn't tell you the whole story, but will give an indication if the motor is sound. Ten kicks with the throttle wide open should give 180 to 190 psi. Lower than 140 psi something is definitely wrong. Ground the plug so it sparks (or press the kill button to prevent sparking).
Maybe you have a stuck piston ring.
2011 EC250E |
I have attached an image. Needs a good clean. Sent from my iPhone using Tapatalk |
Loss of power - suspect power valve | Jonny Halls | Enduro Engine - 2 stroke | 4 | 01-22-2013 09:56 AM |
EC 300 Rattling & power loss ??? | Porkyblader | Enduro Engine - 2 stroke | 7 | 09-09-2011 09:11 AM |
Your 300 Power loss solution? | socalscott | Enduro Engine - 2 stroke | 3 | 07-14-2011 08:39 PM |
Old gas and power loss? | EcEvan03 | General Discussions & Announcements | 16 | 04-27-2011 06:40 PM |
power loss | glassman581 | Enduro Intake/Carburetion - 2 stroke | 3 | 03-22-2011 11:19 AM |
