coolant leakage
I was hoping someone could tell me why my coolant overflow is dripping? the bike has 8 hrs.logged. dripping while sitting idle, bike warm.not hot! I discovered this issue when changing the oil. warmed the bike up and noticed coolant every were . thanks for the help.
Have you tried new cap?
if you overfill the radiators, it will leak until it gets right.. fluid should be to the top of the fins, not all the way full...
Both above replies are on the money. If you don't have the expansion tank and are over filling it it will push any excess coolant out as it warms up. The same applies is the cap isn't sealing or holding pressure. It could also be a head gasket thats allowing exhaust gasses to cross into the coolant passages which then over pressurizes the cooling system and makes it blow the cap valve open.
Try the easy fixes first and see where you end up. It could be as easy as some grit between the caps seal and the rad. |
coolant leakage
Thanks for the response guys. The cap has never been off. Until the discovery of leakage. The coolant level is still top of fins.????? thanks again.
does coolant look good or is there an oily film or any discoloration? if no, then it's not exhaust gas.
is it a 1.2 or 1.4 cap? if it was mine i'd: a: remove cap, start bike, watch coolant swirl a bit. this just checks waterpump operating properly - let it come up to temp a bit, it shouldn't boil until bike gets pretty hot...and fluid level should not change... b: take a good look at cap and replace with known good cap - 1.4 works well. c: triple check coolant level. coolant above the fins will leak out overflow.. d:check for leaks elsewhere - did you see it dripping out the overflow hose? could have come from somewhere else... if the coolant level was high, it shouldn't be anymore - once it blows out the overflow a bit, it stabilizes...
Gas cap leakage problem - "New Seal" | amsmob | Enduro Product Announcements | 16 | 08-24-2011 09:40 PM |
Fuel Cap Leakage | Muzungu | Enduro Chassis & Body | 1 | 05-29-2011 07:14 PM |
Coolant and 1.8 bar cap? | wence | Enduro Engine - 2 stroke | 8 | 03-11-2010 09:31 PM |
Coolant | FFRDave | Enduro Engine - 2 stroke | 33 | 09-13-2006 08:24 PM |
