Clutch cover ?
My clutch is making alot of noise, I want to go in and have a look . Does the cover have a gasket that can be reused ?
Don't want to get in there and find out I need a gasket. |
Mine Was Paper
I just had all he covers off my right side to tighten up the PV linkage and Rekluse install. I got lucky and could re-use the PV and WP gaskets. The clutch cover and right side cover gaskets had to be replaced. The replacements I got from GoFasters: Clutch was paper, but right side cover was rubber coated steel. When I put all the covers back on, I used a little grease on both sides so that I'll be able to pop the covers without buggering the gaskets in the future. Here is a tip that may help: loosen the bolts and back them out a few turns. Tap the cover with a plastic mallet. Once you get a little daylight between a portion of the gasket and either the case or cover, slip a piece of 35mm film or tear-off in there. Then slide the piece of plastic along the gasket. It will likely separate nicely. I got all the way around both my clutch and right side covers and thought the day was saved. But in both cases there was one area around a single bolt hole that was absolutely glued to the case. Since my bike isn't going anywhere because the suspension is at LTR, I had no additional downtime waiting on new gaskets. Gook Luck!
Newest Spanish Girlfriend: 2011 300 Six Days My Daughter is a U.S. Marine |
It is a paper gasket. It can tear on removal.
Just be careful when removing the cover. |
Thanks
Got the first race this sunday . I may wait till I have a gasket in hand , just to be safe. |
You can always make your own. you can buy rolls of gasket material from most auto parts stores. Just good tracing skills, sharp scissors/knife and a hole punch. Can look and work like factory.
Cool . Probably cheaper too.
I'll look into it. |
+1 I've made many gaskets and never had a problem with them. I have even used a brown paper grocery bag for gasket material, worked fine.
Alan 14GasGas ec300r |
The sleeves that the National Geographic magazine came in also worked like a champ.
New Clutch cover | PEB | Enduro Engine - 2 stroke | 41 | 01-05-2013 07:48 AM |
RMW Clutch Cover | Rod Overstreet | Enduro Product Reviews | 2 | 01-24-2011 10:51 AM |
