V-force 3 reeds
For 2009 gasgas EC300, what are the reeds petals required? Are they the same as a honda CR250, do they cross over. Thanks
If you have the V Force 3 reed valve the replacement petals are the same as a CR250. The product code is 3P682M. I just installed a set.
Buy them here: http://www.ebay.com/itm/V-FORCE-III-...223079?vxp=mtr or here: http://www.ebay.com/itm/V-Force-VFor...item19da460df7 |
Thats one to remember.. I think I got stung $150 crazy last time I ordered through the local dealer.
Which year hondas are they for? |
How do you remove that plastic wedge from the inner reeds?
2018 EC 300 |
It says you use a small screwdriver and lever them out. Looks really easy in the documentation. In reality it was a horrid job that had me cursing. Persistance saw me come out alright. The plastic wedges weren't really reusable. Good thing they send new ones with the reeds.
Thanks for the help, I went to my local dirt bike shop (Moto One) they called MOTO TASSINARI and they made sure he had the correct part numbers, They ordered, and i got them 3 days later. $52 plus tax. HAppy
So I took a peek at my V Force 3 reeds and I could see slivers of light thru the upper and lower reeds in the upper right lobe. I took both out and flipped them over thinking they would seal, but no. Time for replacement?
You could run a line of masking tape across the top of the reed block under the petals where the petals clip on to the block to tighten the petals towards the block closing the gap but if there chipped change them..
I tried the tape trick with no gain in closing the gap. Researching the issue isn't much help either. Kind of like oil or tires, opinions vary wildly. I still don't know whether a small gap warrants replacement or not.
V force 2 reed cage | Bailey28 | Enduro Engine - 2 stroke | 16 | 05-18-2011 08:00 PM |
V-Force Reeds | wasp4banger | Enduro Intake/Carburetion - 2 stroke | 3 | 02-25-2011 05:57 AM |
Force Rad Guards | add | Enduro Product Reviews | 0 | 05-09-2009 05:16 AM |
V-force | steve | Enduro Engine - 2 stroke | 2 | 04-03-2008 04:36 AM |
V Force 3 Reeds Question | gasIdaho | Enduro Engine - 2 stroke | 11 | 09-02-2007 12:02 PM |
