learning to rebuild, alot sooner than i am ready for.
can somebody point me in the right direction to a link on how to do a top end rebuild on a kx100 with alot of pictures? my little sister froze her bike up solid on her second ride out with it. im also on my first bike so i have only the vague idea on how to do the rebuild, so help would be greatly appreciated.
03 ec250 hyde skidplate, cycra handguads, protaper contours "what? it seemed like a good idea at the time!" |
chris 07 EC300 force rad guards, os pv cover, |
link will not open for me... but thanks!
2004 GasGas DE250 |
take out the plug and fill the jug full of oil, wait a week, drain it out and kick it with no plug for a while then put the plug back. its not the best advice(in fact it may be the worst), but it worked MANY times on our old(70ish) kawi 175
Le Crutan 98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD) FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck: |
im thinkin its a stuck piston or a ring that got messed up. im curious though, how would you drain the oil out? and what oil would you use? since it may be cheaper to get a new jug, your idea is rather intriguing, if only for discussion..
usually hot seizes can't be fixed with fluid in cylinder...
go to kawaski.com click on owner info->parts diagram->kx100 (or whatever it is)->cylinder/piston that'll show you what's going on in there, so you'll have an idea of the parts. the process is the same for every water cooled 2 stroke. drain radiator remove head remove cylinder base nuts pull cylinder off (if pv you'll need to unhook first) put rag in crankcase cylinder mouth remove circlips from piston pin push piston pin out (proper tool helps..but socket will work) once it's apart you will need to check - piston, rings, cylinder,small end bearing, pin, and big end bearing play. you also need to clearance new piston, rings, etc. you will probably need a book to get specs for cylinder wear/etc. if you hot seized, you'll probably need a rebore/new piston/rings/pin/bearing and circlip. it's easier and harder than it looks to do it right you may get away with just honing the cylinder (if the damage is MINIMAL - don't forget that piston slides up and down 10000 times a minute) but if it seized i would not reuse piston/rings/pin/bearing or circlips.... overall you're talking between $100 and $300 in parts i would think. rebores are cheap (usually $25ish). pistons are cheap for kx100 i would think (under $100).... any competent motorcycle shop could do the job in 2 hours or so (minus the rebore).
Need help learning to stand up!! | skid jackson | Riding Techniques & Training | 56 | 02-28-2013 12:26 PM |
Ready for the Weekend | cladoo | General Discussions & Announcements | 0 | 05-20-2010 08:09 AM |
Getting ready for a new gasser | pbspecial | General Discussions & Announcements | 16 | 04-24-2010 06:08 AM |
Need help learning to sit down! | Magellan | Riding Techniques & Training | 24 | 05-09-2009 10:06 PM |
My Gas Gas ready to go! | cladoo | Pictures & Videos | 5 | 05-22-2007 06:09 AM |
