'06 EC300 Rear wheel bearings
The manual is a bit "vague" as to the vendors part numbers for the bearings and seals. Our local dealer collapsed so we are in a bit of a tight spot in SA right now, so herewith the part numbers for the bearings (I used SKF products)
Parts Manual reference SKF Number Item 9 (small seal) 25x42x7 CC Item 44 (big seal) 32x42x7 PU Item 8 (small bearing) 60042RSR (2 Required) Item 59 (big bearing) 60052RSR Hope this helps anyone in a fix.
'06 EC300, '06 FSE450, both 'tricked & treated" |
have fun, j. |
That's what I bought and fitted to my '06 EC300. Running fine, no problems
Good, Ec '04 is different. have fun, j. |
Rear wheel bearings on 03 | kendunn | Enduro Chassis & Body | 8 | 01-06-2011 05:43 PM |
Rear Wheel Bearings | cladoo | Enduro Chassis & Body | 2 | 11-18-2008 10:14 AM |
05 ec 300 rear wheel bearings | burgo | General Discussions & Announcements | 1 | 06-08-2008 03:32 AM |
rear wheel bearings | smithys ec250 | United Kingdom | 3 | 04-23-2008 04:01 PM |
Rear Wheel Bearings | gasIdaho | Enduro Chassis & Body | 7 | 02-14-2008 08:34 AM |
