Swingarm bearing numbers?
G'day,
I was wondering if anyone had a list of swingarm, aftermarket( SKF?), or the like, bearing numbers? I would probably be keen to change them all. I have access to a workshop in Finke and can change them up there. I don't want to get the bike half done and then have to rush it before I leave. Before anyone asks, I actually thought they were fine and hadn't noticed any play till the other night Cheers Mark
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E |
I've bought the bearings (needle rollers and cage) through the local allied bearings before, but they can't supply the inner bush.
Inner bush for which part mate?
Have you got a detailed list of what you got by any chance? Cheers Mark
SWINGARM BUSHING BE250312007 - Haven't checked to see if its the same part on the newer models but would assume they are. The bushing is the sleeve that runs between the axle/pivot and the bearing. On the swingarm they push in from the inside.
All the bearings linkage and swingarm are the same 22BM2816 NEEDLES BEARING (22x28x16). Any bearing shop should be able to get you needle rollers in this size. Width can vary a bit if needed. The inner bush should be ok to re-use, unless if its really been flogged. |
I must owe you a heap of drinks when I finally get up your way Cheers Mark
Get an All Balls kit.Has everything in it.
2012 Headstem bearing numbers? | wence | Enduro Chassis & Body | 4 | 06-30-2013 06:27 AM |
Swingarm bearing depth? | Neil E. | Enduro Chassis & Body | 1 | 05-13-2013 02:21 PM |
Anyone know 300EC Crankshaft Bearing Numbers? | LandRover | General Discussions & Announcements | 1 | 05-10-2012 03:32 AM |
need main bearing part numbers | mxdj2003 | Enduro Engine - 2 stroke | 0 | 03-15-2010 05:07 PM |
Moose swingarm bearing kit - not so good... | stay_upright | Enduro Suspension | 6 | 03-03-2008 03:00 AM |
