Pipe dent remover
I have a similar dent tool, you need to heat the pipe more you could get much more of that dent out, I could get that at least 90% out you look like you have only got it about 50% better. You need 80-100psi and heat the pipe slowly so you can watching the dent come out so you can apply more heat in the correct area.
It was my first go with it. I was a little nervous but will give it a good heating next go around.
I found with my home made death trap contraption to plug the ends, then heat the dent, and only then to apply air pressure. If I pressure it up before applying heat, the thermal expansion of the air inside the pipe overwhelms the safety measures on the plugs.
In short: Heat first then air = good. Air first then heat = dents in garage door.
Phil (New bike pending...) |
Good points! Also you can engineer a built-in leak by putting a valve on the other end that you can crack open, then as you heat the pipe just watch your PSI on your gague
here we used about 30psi, much more in my comfort zone: https://www.youtube.com/watch?v=idxX...qKv0RIp9jl6463
07 GG EC300 11 GG EC300E |
You need to remove the carbon and oil inside the pipe before in order to prevent pressure increase.
www.endurohp.eng.br Sherco ST300 2015 (Trials) https://www.instagram.com/leocm74/ Brasil! |
My experience ist not the air pressure is the secret to remove the dent, it's this heat. I always used the normal small gas lamps like in the video with no good results. Last time I used a butane burner which gives much more heat and a larger area of heating. It works much better and easier to remove the dents.
4 strokes are only good for power generators |
the guy i use, uses water in the pipe
Got word that Brett with BonJoesCycleSport would be at the Little Brown Jug AMA national enduro this past weekend. So I took my 2 worst pipes. One was almost flattened at the largest diameter.
Report; nice guy. Professional. Did an unbelievable recovery on very bad pipes at a great price. Absolutely recommend. 716-773-5800 http://www.bonjoescyclesportinc.com Or you can continue to screw around in your garage and put your eye out while leaving ripples and dents.
2011 EC300 Six Days 2010 EC300 Nambotin Replica |
P3carbon fiber pipe guard Gas Gas stock pipe 08-11 | REVERUP | Enduro Product Reviews | 28 | 12-30-2013 09:05 PM |
Crank Remover and Crank Installer tools for EC250 | Fabry | Enduro Engine - 2 stroke | 5 | 06-25-2013 07:24 PM |
Pipe dent | GasTimppa | Pictures & Videos | 6 | 11-06-2012 04:10 PM |
Pipe Dent Removal | savage sausage | United Kingdom | 22 | 02-21-2012 07:51 PM |
Dent Removal | PEB | Enduro Engine - 2 stroke | 7 | 12-27-2007 09:23 PM |
