Riding Techniques & Training Increase Riding Skill, Physical and Mental Training, Weight Loss. |
Can anyone tell me exactly what the numbers keen on 2 x online springs I have 1 596-08/4.9
2 596-10/5.2 Cheers
GG ec 250 1998 v strom 1000 2008 |
4.9 & 5.2 is the weight rating of the spring. Most Gassers came with 5.2 as stock spring
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro ![]() |
Thanks very much.
Good info as I have been told the 5.2 is the wrong one
Might be for your weight. What is your weight? Geared up and ready to ride?
so what is the difference where one spring is 10 and the other is 8? what do those numbers mean?
If I remember correctly the first set of numbers (596) is the series and the 8 & 10 are the order they are listed in the Ohlins parts catalog. Pretty sure there is a 5.0 spring in between the 4.9 & 5.2- it would be stamped 596-9/50
![]() Quote:
8mm does sound a bit small but 4.9 is a light spring rate. |
Yes, the 06 200 has 50nm spring as std. I am about the same weight as you and use a 5.6 kg spring from Enduro Engineering. I use 0.45 kg springs in the forks.
Sent from my OMNIA7 using Board Express
Thanks Anders, I thought it was too soft. I'll check the springs too because they do dive.
'00 Montesa Cota 315R '13 Husaberg TE 300 |
Fork bleeders for Ohlin forks. | Porkyblader | Enduro Suspension | 1 | 11-15-2010 11:36 PM |
2003 EC 200 Ohlin rear spring | lankydoug | Enduro Suspension | 8 | 08-30-2010 04:35 PM |
