Old 01-09-2013, 12:25 AM
singletracker singletracker is offline
Default Lectron Carb
As some of you may know I was fed up with having to keep a close eye on the air seal at the bell of my carb and air box, so I bought a new carb. I know there are other fixes, but I was also looking for a little better power at high and low RPM's and better fuel mileage.
I probably wouldn't have even considered getting a new carb if it wasn't for all of the talk about APT's Smart Carb. Strangely enough I didn't even know Lectron existed until it was brought up in the SC thread.
Anyway, I didn't want to wait until May 1 to get a SC, and after researching the Lectron and speaking to the owner of the company I was convinced that it's on par with the SC regarding performance and may have an advantage or two. I would feel much better about the SC if they had all of their bugs worked out, and there were reviews to back it up. Specifically, the cable fitting issues and the engine flooding. One of the selling points for me regarding the Lectron was that they set up the carb for my bike, riding conditions and type of racing. Before they shipped it they even put it on a dyno to make sure all was in good order. I also like the fact that it has vents so I don't have to worry about it flooding my bike any worse than a normal carb. Hey, it's worked for years so why change it? I know why, but I'll probably kill more trees by running in to them than leaking gas.
The good news; IT LOOKS LIKE IT IS GOING TO FIX MY FITMENT ISSUE! WOO, HOO! Its about 6.7 mm longer and the bell is about 2.8mm smaller in diameter, so it fits nice and snug now. I don't think I'll have to worry about the clamp coming off now.
The bad news; I had to modify my stock cable to give it more slack. It barely had enough slack with the stock carb, and since this one sits back a little further I had to reroute the cable slightly and cut off about 16mm of the cable housing to give me the slack I needed. It still just barely has enough, but it should work. All it cost me was a little time. Of course they have a cable that they'll sell you if you want to go that route.
I got the adjustable power jet so I won't have to take it apart to adjust the top end. Once the metering rod is set I shouldn't ever have to take the carb apart at all, and there is a good chance that the metering rod won't have to be touched to begin with since its been dialed in for my bike at the factory. The owner of Lectron, Kevin, said that once it's set the only thing I should ever have to adjust is the idle screw and that's if I have more than a 2,000 foot elevation change. That's something I don't have to worry about around here.
Unfortunately, I don't have a ride report yet. I still have a few other things to put back on the bike, and I've been down in the back today. Hopefully, I'll get a short ride on it before the end of the week. More to come.
2011 250xc Race
Old 01-09-2013, 05:36 AM
Really looking forward to your ride report. I jumped the gun, bought the hype and placed my preorder on the smart carb cast version. I'm hoping I don't regret the purchase.
Old 01-09-2013, 06:52 AM
nambo-trev's Avatar
nambo-trev nambo-trev is offline
I'm very interested in your ride report as well! What did lectron say(if anything) about the differences benefits or not about the lectron compared to the smart carb?
trevor
Old 01-09-2013, 07:36 AM
Nice and compact.
How is access to the choke knob?
Old 01-09-2013, 08:15 AM
Originally Posted by gasgasman View Post
Nice and compact.
It looks like it will be a bit of a reach, but I haven't tried it while on the bike yet. I read elsewhere that they have a lever type that sticks out to the left side of the bike for easier access though. If this is too much of a pain I may ask them about it.
2011 250xc Race
Old 01-09-2013, 08:30 AM
The biggest difference I see is the air density compensation, and the "scoop" in the bell and lack of vents needed to accomplish this. The Lectron has a large selection of metering rods they pick from at the factory to get you close. Keep us posted, Kelly thought it was good, but the SC was perhaps a little better. I went with the cast SC because the billet is just too expensive and bulky, I can't ride here until March anyway, there are only two races before May 1st, and I have the Keihin dialed in very well. I'm hoping to smooth the power a bit and add a little grunt, as this bike seems to have more of a mid/top personality with a little more hit than my '07.
Old 01-09-2013, 08:13 AM
I mentioned to him that the only reason I knew about his carb was because of the SC, and he casually acknowledged them. I'm paraphrasing here, but he went on to say that companies have tried to duplicate the Lectron but they are unable to. He said the metering rod isn't a straight taper, so to speak, and that it can't be duplicated. Later he also mentioned that Lectron is the only company that puts every carb on a dyno.
I haven't spoken directly to anyone from Smart Carb, and I don't want to come across as slamming them in any way.
2011 250xc Race
Old 01-09-2013, 08:45 AM
nambo-trev's Avatar
What about fuel atomization and fuel economy? I wonder if there both pretty much on par with each other? It just seems strange to me that lectron hasn't been as big of a topic(if at all) and the SC is coming into the picture as a revalation to most people so to speak?? Is the only thing the SC have over the lectron a broader range in terms of elevation? I don't want to ask Corey or Kevin because there opinions will undoubtably be somewhat biased as would mine if I owned the company. I too am not trying to knock one for the other but the lectron is almost 100 bucks cheaper and I don't ride outside of a 1500ft elevation change.
trevor
Old 01-09-2013, 09:08 AM
I think its more than just a correction for altitude and temp. Its also a correction for engine tolerances and the different signal they create. Look at how Keihin jetting varies. The SC has what is essentially a feedback loop, so any differences in demand are a wash once corrected, and the initial metering rod adjustment made. This is why they can use just one metering rod for a wide range of applications. No need for an array of multi tapers, its all done by the variable fuel pressure in the bowl in relation to the vacuum signal at the rod/nozzle. You adjust the OVERALL mixture by the mechanical position of the rod, and its taken care of at different points in throttle position.
The only thing I can see being perceived as a limitation is that there is no way to intentionally tune a certain area alone slightly rich or lean, like is done in the case of mellowing out a 300. On the flip side, this is usually done as an alternative to needles/settings with less than linear characteristics, that we just happen to be bound to due to availability. This is a very different way to think about fuel delivery.
Old 01-09-2013, 09:29 AM
When I mentioned to Kevin from Lectron that I read Kelly's reviews, he stated that he was really pleased that Kelly was so happy with the carb considering he sent him a generic carb that wasn't completely set up for him.
From the research that I've done it seems that Lectron made some significant advances in their product in the past five years. It appears that it was more of a drag race carb prior to the new ownership and recent advancements in technology.
In Kelly's latest review he made an adjustment to the Lectron for the first time, and said;
"Also got some testing in yesterday. Dropped the rod 1/2 turn (super EZ to do). While my bike seemed to run perfect before the plug read slightly rich. The leaning of the rod made it more snappy. I also richened the power jet (twist the external knob) and that to added top end. Seems perfecter now. :>) Carb still runs flawless from bottom to top. Buddy Ken with a KTM 350 tried it and really liked it. He said "wow, that carb is different, I see what you mean, fluid smooth power everywhere with zero glitchs""
I'm anxious to see for myself how it works on the GasGas.
BTW, it sounds like GMP knows a lot more about how these carbs work than I do.
2011 250xc Race
Lectron Binni Enduro Intake/Carburetion - 2 stroke 16 03-29-2011 09:44 PM
RB carb 101racing Enduro Intake/Carburetion - 2 stroke 15 05-22-2009 10:33 AM
RB Carb Mod RBD Enduro Product Announcements 10 06-29-2008 07:57 PM
RB carb spdfrek Enduro Engine - 2 stroke 2 03-22-2008 10:28 PM
