48mm zokes?
Just wanting to top up the oil in the forks and have bought a cap spanner.
So far so good until I try to undo the cap? It undoes to a point and then clicks like it is skipping over the end thread. Do I need to remove anything else beforehand? Thanks in advance, Mark Just looking at the manual I must have to pull the outer down I guess? It is still in the bike so therefore I will have to loosen the clamps a little and slide the outer down. Please let us know if I am incorrect.
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E |
G'day wence, if your changing the outer oil, wheel, brake calliper off, loosen all triple clamp bolts, slide out forks, undo cap, slide down black slider ( I think that's the part you werent sure about) , invert fork over oil catching bucket. if you don't have a set of soft jaws for your vice, then handlebars off, slide up forks up in clamps slightly to clear the bottom bar riser, softly tighten bottom triple (soft), undo cap. If your doing the inner chamber as well, you'll need to follow the manual. You can buy a cheap rain guage from a 2 dollar shop and add 320ml each leg. Cheers
Cheers mate,
Been a long few days . I figured I would have to lower the outer instead of trying to pull the guts out Thanks for the help mate. I am just about to add about 30mm to each leg as the fork is consistantly clunking on the stop after any sort of jump. Cheers Mark
think it was about a year ago when the first 2012 came out
Clunking on compression or rebound?
I should have said bottoming out I suppose. Just cluncks as the fork bottoms out after a jump.
Cheers Mark
Thread Tools | |
Display Modes | |
Need some help changing (inner) oil on new CC 48mm Zokes. | CDBiker220 | Enduro Suspension | 12 | 02-28-2013 09:19 PM |
48mm Forks | Scramble Champ | "Wanted to Buy" & "Want To Trade" | 1 | 02-28-2013 07:09 AM |
New Zokes | Fred1956 | Enduro Suspension | 2 | 12-05-2012 12:35 PM |
My 48mm Kayaba Project | Ed Ventura | Enduro Suspension | 29 | 09-03-2012 04:22 PM |
48mm zokes | dublin | Enduro Suspension | 0 | 06-05-2011 05:34 PM |
