2009 ec 250 swing arm pivot removal ?
nut losend, the pivot bolt should tap through the swing arm to realise swing arm from frame ? is this correct as i'm not getting movement when taping/striking with wood & hammer
Have you loosened the brackets that connect the swing arm pivot to the frame to the linkage (3 points of contact)? Need to loosen these at the frame.
2006 Gas Gas EC250 2011 Husaberg FE390 |
thanks
yes, the brackets were unbolted and rotated back to necessitate one of the linkage bolts removal, they were tight to lever back, thanks for the reply, il look after work today. some general internet search is "have you slackened the engine mounts" il phone GG UK for a pointer, please pitch in any ideas.
Yes, I have also read that loosening the engine mounts helps as well. I have not had to this on my bike.
Sounds like the swing arm pivot has not been removed in years. I am able to remove mine without loosing or removing anything but the dog bones.
Try heating the engine case where the pivot goes through it. Then use a drift and heavy hammer/sledge to pound it out. When you reinstall, make sure you grease it with good waterproof grease.
2004 GasGas DE250 |
thanks
hitting is the way forward...its not been out from factory..looking to get this one ship shape soon, thanks..... & il check yearly from then on
Pivot Pegs | Wicitup | Enduro Chassis & Body | 16 | 02-14-2008 03:15 AM |
Swing Arm Bolt Removal | RPB111 | Enduro Chassis & Body | 5 | 12-28-2007 04:18 PM |
