Help.. Jetting problem?
Bike year & model = 2001 enduro ec300 (2stroke)
Temperature Celsius = 0 - 30 Elevation =0-1000meter Main jet = 182 Pilot jet =40 Needle & notch =n1EF notch = clip on highest point( needle lowest) Air screw setting =2,5 Throttle valve/slide =7 results: from 0% to 40 % trottle the engine responds well . if i go from 20a30 % trottle to WOT the rpms goes up but... it takes a 2 or 3 seconde to reach max rpms !it s like i should pull THE chocke a little bit up when i open THE trottle when i close the trottle then and open it again right away,then it works Great,straith to max rpms.if i let HIM idle for 15 Seconds i got THE same problem again.. i gues he is to rich ??? Sombody Any suggestions for my what i should change first? Pilot jet ? I tryed THE needle clip 1 groove down but That is even worse The owner before me did trial tracks with this bike.. Thanx and sorry for my bad englisch. From Belgium Stefan |
If you raised the needle and it got worse, that suggests a rich condition. First, I would try a 178 or 180. Not a huge change, but little steps.
Yes, he was to rich! :-)
I changed the pilot jet from 40 to 35 and also changed THE main jet from 182 to 165 I got THE main jet laying around... Now he Goes fine. No more problem when riding slow and open THE trottle full , he shoot to max rpm without Any problem and fast. Now its a task to find THE biggest main jet he could run..without THE problem return If i try THE main jet of 182 i got THE issue again but just a little bit.. I Will try a 175 main jet? Will iT make a big diffirence from 165 to 175 main ?becouse he is driving smooth now...but i wanna be sure i gotTHE best jet... Thanx for your advise ggrider |
Ok, those are not little steps!
Try a 175. Buy a 178 if you can. I'm positive the 165 is going to be too lean. Don't use it for very long, or don't ride hard if you do. Then try a N3EG needle! The likely reason you felt the need to go to a 35 on the pilot is because the needle is too rich.. The straight section of the needle (denoted by the last letter, F, G, H, W, etc) plays a significant part in the idle circuit. The stock N1EF is too rich all around. I would not recommend the 35 pilot. It might respond really crisp but will generate excess heat and not have as much power. I am currently running a 42 pilot and 175 main. Currently testing a N3EG at the behest of another user here. |
42 with n3eg is a bit too rich, I use 42 but only with n3cg and 178 main.
Thank you for the good info.
I Will change the needle asap. And hope it will fix my problem. And i Will change THE pilot back to 40 A 175 main is in the carb now and a 35 pilot And he is stil a little to rich at WOT Cu later Last edited by Stefan Baele; 08-26-2016 at 01:34 PM. |
Tags |
jetting problem |
Thread Tools | |
Display Modes | |
Jetting problem - JD / spooge / spluttering | jocser | Enduro Intake/Carburetion - 2 stroke | 39 | 05-16-2016 03:46 PM |
2002 ec250sm jetting problem | chrisboy | Enduro Intake/Carburetion - 2 stroke | 9 | 05-10-2013 12:43 PM |
I bought a 2000 xc and keep finding problem after problem | 675AZ | Enduro Engine - 2 stroke | 12 | 02-15-2013 07:25 PM |
jetting problem/quiery... | lonetree | Enduro Intake/Carburetion - 2 stroke | 27 | 08-11-2012 07:20 PM |
idle problem/jetting question 03 EC250 | bryanaverill | Enduro Intake/Carburetion - 2 stroke | 16 | 06-07-2011 04:42 AM |
