Kx 85 problems
Hi guys I know it's not a gasser but thought u might be able to help .. my mates Bought a kx 85 that has a few problems .. first problem is when u kick it into gear unless your revving the tits off it it'll die .. and the second problem is any sort of small hill it'll bog down an die , but on the flat it rips tidy .. had the carb cleaned which helped a bit .. the bike starts up easy enough and will idle for as long as u want it too ..
Well I'm getting a KX85 in my shop tomorrow that belongs to one of my sons friends'. It has the same problem. I'll let you know what I come up with
Matt 1999 GG EC 250 Six Days 1999 Cagiva Gran Canyon 2001 Aprilia Falco 2001 Triumph Speed Triple for my 20 year old 2000 GG XC250 for my 20 year old 2003 Honda Rancher 350 for the wife |
Check float height. And if it has a clutch, it sounds like it's sticking...
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
Usually a bog is caused by a lean condition so make sure you can see through the pilot jet. Also check the intake manifold for cracks/leaks.
pull the clutch cover off, pull the plates off and check for wear marks in the inner hub and basket, if theres grooves in them itll make the plates stick........
Pilot jet and old plug on the bike I worked on today. Turns out it was a ktm85 not a kx.
Thank u guys for your help I'll pass the info onto him . Thanks again
Thread Tools | |
Display Modes | |
More ec 200 problems | gump147 | Enduro Engine - 2 stroke | 9 | 06-01-2015 03:15 PM |
yet more problems | bonkeye | Enduro Electrical & Wiring | 9 | 08-17-2013 09:48 AM |
250 ec rear end problems | marjastaja | Enduro Suspension | 2 | 09-04-2009 06:04 AM |
03 300 Problems | Ryan#87 | Enduro Engine - 2 stroke | 3 | 06-15-2008 10:28 AM |
06' ec 200 problems | speed addic | Enduro Engine - 2 stroke | 0 | 02-25-2007 06:44 PM |
