Old 08-01-2017, 09:18 PM
periclesgsilva periclesgsilva is offline
Default Charging question EC250 2013 e stsrt
Hello guys. I have a problem with my GG. My battery is not receiving full charge. Measuring the stator the white wire are sendig less than yellow. So probably the charge coil are with some problem. For a quick alternative. Can i use the yellow to charge the battery? Until disassembly and send to repair? I mean change the plugs position before rectifier? The white are sendig less so for front light i presume Will be ok.
Old 08-02-2017, 12:39 PM
Well, some update on situation. Like i said, my white wire was low on power. So, i changed after the rectifier the yellow for white. White on headlight and yellow to battery. Works great. Until i send to repair (enduro this weekend).
Thanks!
Old 08-02-2017, 09:40 PM
Correction: before rectifier. After the stator i changed the wires
Enviado de meu SM-G935F usando Tapatalk
Charging kiwigasgas Enduro Electrical & Wiring 25 10-06-2016 03:59 AM
not charging battery OLD.IT Enduro Electrical & Wiring 2 06-21-2015 03:01 AM
Charging phone on 2011 EC300 Quigs Enduro Electrical & Wiring 9 03-07-2015 12:55 AM
Battery Not Charging GLantern Enduro Electrical & Wiring 6 08-25-2013 03:45 PM
2013 question... rbm33 General Discussions & Announcements 55 09-06-2012 05:20 PM
