Can anybody please point me to some good Crank Remover/installer tools that works with Gas Gas 2 strokes?
Tusk (rmatv) sells one, however I never required one when I did my bottom end. The cases split easy enough (once all the bolts are out). If the crank doesn't come out a few taps with a plastic/rubber mallet moves it easy enough. For installation I simply froze the crank with some dry ice and it dropped right in.
I didn't have to use any install tools, are you having issues? I know that motion Pro makes a very nice press and puller, they are affordable and pretty stout. But, again, I haven't had any issues installing a crank into the bearings if you freeze everything before installation.
Phil (New bike pending...) |
![]() Quote:
Thanks for the tips. |
Check out Jakobi's rebuild thread here, he sorted everything out pretty well (two or three times in places
True that! That was my first ever bottom end. Learnt a few things.. Next one will be a walk in the park.
gas gas ec 200 crank | chinesegav | United Kingdom | 5 | 11-27-2012 06:49 PM |
Crank it up! | Rick | Pictures & Videos | 2 | 04-09-2011 12:36 PM |
2007 EC250 Crank Bearing? | BIG TOOL | Enduro Engine - 2 stroke | 9 | 11-23-2007 02:47 AM |
