Old 08-26-2014, 03:54 PM
stian stian is offline
Default Piston Size EC300
Hi. Un-marked cylinder on my EC300 07, in need of the measures for A,B,C,D piston. Anyone?
Thanks
Old 08-26-2014, 04:45 PM
Moto7man Moto7man is offline
Did you look under the intake for the letter?
―Comedian Lewis Black
-Unknown Sardaukar
Old 08-26-2014, 04:47 PM
You'll need a bore gauge to determine what size piston you require.
http://www.wossnerpistons.com/
Difference from A to B is 0.01mm, and so on from B to C etc
Old 08-27-2014, 09:09 AM
The cylinder is marked E on the intake side, 2cm from bottom. Clearly, piston size is marked A-D, so cylinder is unmarked.
Using a bore-gauge tomorow. Typical that im in a hurry and get and unmarked cyl.
Still have not answered my question thought. I still doesnt know what size A, B or D is. If I measure XX,96, still doesnt know what piston I need.
Please clearify what size for example A piston or D piston are.
Old 08-27-2014, 10:42 AM
Elvis74 Elvis74 is offline
The clearance between the cylinder and the piston should be around 0,06mm!
Means, when measuring 72,00 on the cylinder the piston is 71,94!
Old 08-27-2014, 01:37 PM
Anders Anders is offline
If you take a look at Wossner's home page and select your engine size and year, they will show you what bore size pistons A B C will fit.
Old 08-27-2014, 02:05 PM
Sat on my phone due to work.
(penger er forovrig overfort, igjen; takk! )
Old 08-27-2014, 04:27 PM
hamilton's Avatar
hamilton hamilton is offline
Since I was bored here's the sizes.
std bore - 72.00mm
A piston 71.93mm
B piston 71.94mm
C piston 71.95mm
D piston 71.96mm
0.07mm piston clearance
as per Vertex
15 GASGAS EC 250
19 Sherco SE 125R
Old 08-28-2014, 04:47 AM
std bore - 72.00mm
A piston 71.93mm
B piston 71.94mm
C piston 71.95mm
D piston 71.96mm
as per Vertex
My cylinder is 72,01mm. Makes my piston with 0,07 in clearence a B piston.
isnt 0,07 too much? Ive heard more 0,05-0,06 (making my piston A)
Old 08-28-2014, 05:53 AM
Thats backwards. An A piston will give you more clearance again. Based on what you specced your cylinder at Wossner suggest a B which gives 0.07mm clearance. Thats a forged piston, so you may wish to run a bit more than a cast. I'm sure you could drop a C piston in and still be fine, but what if..?
What was the size of the piston you just pulled out?
Piston size, A/B/C. How important? jdosher Enduro Engine - 2 stroke 5 01-28-2013 08:16 AM
What "size" piston without removing barrel Eugene Enduro Engine - 2 stroke 20 01-04-2012 10:55 AM
What size of piston? Todd5774 Enduro Engine - 2 stroke 3 10-24-2011 03:20 PM
no piston size stamped on cylinder? stainlesscycle Enduro Engine - 2 stroke 0 08-10-2011 06:44 AM
Cylinder measurement results below so which size piston? stay_upright Enduro Engine - 2 stroke 1 07-28-2009 12:43 AM
