Old 05-18-2015, 02:22 PM
safetythird safetythird is offline
Default Can I remove my EFI and install a Carb?
I have a 2003 gasgas 450 FSE. It stall all the time and right at the worst time too. Our local Gasgas Guru says there is nothing he can do. I'm wondering if I can swap it out for a regular carburetor??? Has anyone done this before on this site? I need help. I don't know how to trim the idle up or down. Bike only has 3300 km since new.
Old 05-18-2015, 03:08 PM
Tbucket's Avatar
Tbucket Tbucket is offline
You need to post this in the 4 strocke & EFI section.
Old 05-18-2015, 11:15 PM
Elvis74 Elvis74 is offline
Why don't you just try it.....
I don't think you will find somebody who did this before.
Gesendet von iPad mit Tapatalk
Old 05-18-2015, 11:19 PM
It has been done before.
Old 05-19-2015, 08:06 AM
'm still new at posting. Thank you for noticing. I'll use the correct forum next time. Stephen
Old 05-20-2015, 10:21 PM
jimjim jimjim is offline
Alot have guys have done this swap on Suzuki LTZ 450 quads,someone even makes a kit for that swap.
Old 05-21-2015, 03:58 AM
MercyFlush MercyFlush is offline
Your Guru mustn't be all that guru esq.
You can probably fix the issue with an ECU adjustment. Going to a carb just sounds like a back-asswards way to fix the problem
Old 06-07-2015, 11:50 PM
INABIL INABIL is offline
The '07 Pampera had a carbed 450 4-stroke.
Bill
'03 EC400fse
'95 KX 250
Old 10-07-2015, 04:42 PM
Yngvim Yngvim is offline
Try adjusting the throttle body it sounds like the tps is just outside the limit of the ecu. Do you need to open the throttle a bit when you start your bike.
Sent from my LG-D855 using Tapatalk
Old 10-08-2015, 05:14 AM
Vindicator Vindicator is offline
I have seen one in Portugal up and running also but don't know the details of the transformation .
Vindicator
'11 EC 300R
How to remove Flywheel? Fabry Enduro Engine - 2 stroke 12 08-16-2013 03:27 PM
How to install a Keihin Carb 19brendan81 Enduro Intake/Carburetion - 2 stroke 2 01-17-2012 09:10 PM
How to easily remove and install that pesky Keihin mlyle11 Enduro Intake/Carburetion - 2 stroke 6 01-04-2012 11:34 AM
how do you remove the kickstart noobi Enduro Chassis & Body 13 09-22-2011 03:31 PM
