Old 02-09-2018, 11:40 AM
jcs003 jcs003 is offline
Default Stroker Crank
Does anyone sell a drop in stroker crank? if not, who is a recommended builder to do the work?
Thank you,
John
Old 02-09-2018, 08:39 PM
PEB PEB is offline
For a 2 stroke? I have two used 2 stroke cranks for sale if you want one to send out to have work done on and not tear down what you have.
Old 02-11-2018, 01:00 AM
WHat is a stroker crank? Tried google but not sure it is giving me the right answers
Old 02-11-2018, 01:44 AM
(F5) (F5) is online now
Well the easy way is to find a rod with a bigger pin so you can offsetbore the crank for more throw.
Why would you bother?
The right needle and a head reshape will bring you more performance
Old 02-11-2018, 04:31 AM
Anders Anders is offline
Its a crank with a longer than "normal" stroke.
Old 02-11-2018, 08:13 AM
I believe you can weld the existing hole and use the stock size pin. Stroker cranks need to be rebalanced to prevent bad vibes.
Big bore kit is another option.
Old 02-11-2018, 12:39 PM
gasser's Avatar
gasser gasser is offline
If I remember right Jim Cook used to have a stroked out 250 - maybe he'll have some info for you.
Old 02-12-2018, 12:39 AM
does that not increase the compression?
What are the benefits of this mod over just ensuring proper squish or modifying the head (insert) to increase the compression?
Old 02-12-2018, 01:46 AM
This is a trick mostly used in forstrokes to increase the capacity, like boring out the cylinder. Whether you select to bore or to stroke (or both) would depend on how you want your engine to perform.
You would have to raise cylinder to bring the compression down to normal, often done by placing a spacer under the cylinder. But on a twostroke, a stroker crank would also lead to changes in the port timing, making it more difficult to just add a spacer.
Old 02-12-2018, 02:54 AM
RBrider's Avatar
RBrider RBrider is offline
Thank you,
John
There's a engine builder in the PNW that builds 2 stroke strokers, but for the life of me can't think of his name. I believe someone on this forum has a long stroke GG done by this person. Maybe in the Chicago area.
RB
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
Long/Stroker rod for 01 XC? jgas Enduro Engine - 2 stroke 20 10-31-2012 01:49 AM
stroker rods. Dude Enduro Engine - 2 stroke 9 07-06-2011 04:42 PM
Which stroker oil...? Gonzo Enduro Engine - 2 stroke 10 03-11-2007 05:42 PM
