Old 02-09-2023, 09:09 PM
brider brider is offline
Default '03 EC300 Nissin front master cyl kit?
I can't seem to find on-line a rebuild kit for the Nissin front brake master cyl on my '03 EC300. Gotta be a common kit for many years, what's a good source, for this and the rear brake and clutch, too?
Old 02-10-2023, 03:15 AM
(F5) (F5) is online now
Easy as, but, as usual you dont say which planet you live on.
At some point the masters get oval bore as ally bore. Some places will offer stainless sleeve insert. Or buy another low mileage one of same size and outlet.
Check carefully the size of master cylinder. Front will be 11mm, but rears change. Cast on the side.
Old 02-17-2023, 08:35 AM
Touche' ! Got me there, although in this day and age I was ASSUMING an on-line source, which doesn't care which planet I live on.
I'll continue to search, but I would imagine it's common to swap in a non-Nissan M/C & lever unit with the same bore & outlet config.
Old 02-17-2023, 02:58 PM
ditezz ditezz is offline
Replace the Nissan with a brembo .All you need is a brembo banjo bolt as it is a different pitch but still 10mm.Putting a MC with a smaller piston will give a softer more progressive pull .Personal choice though ,I found the Nissan way too abrupt
Old 02-17-2023, 05:43 PM
Ahh, you want an New Zealand site
https://lamoto.co.nz/daytona-nissin-...pair-kit-11mm/
Old 02-17-2023, 05:51 PM
Rear brake is a little trickier, there a a couple of sizes. It will be cast into the cylinder, something like 1/2 which is a fraction of some antiquated measuring system involving inchworms or something ?
The clutch back then I'm not sure if it used DOT4 brake fluid or mineral oil. Will be written on the clutch cylinder cover.
You will need the right seals to match. DOT will be something like Nitrile and oil; EPDM, but you dont need to know that, just what type of fluid they use for the kit.
Old 02-17-2023, 09:22 PM
Well,first you'll need to know the brand of your clutch master, then the size .Early gassers used AJP ,Braketech or whatever they had on the shelves ,you probably find the clutches use Mineral oil (usually denoted by a green cap on the master) the brakes are Nissin ....Honda ,Yamaha ,Kawasaki every one used them .Find out the piston size and it will be easy to find
Old 02-18-2023, 10:01 AM
cbutler's Avatar
cbutler cbutler is offline
This is what you need way to much thinking going on and how the hell did a CLUTCH get involved with a FRONT BREAK question.
https://www.ebay.com/itm/20249266517...3ABFBMqvTV08xh
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 02-18-2023, 05:25 PM
This is cheap Chinese knock off crap ...AVOID .As I said ,you can buy a rebuild kit From Honda ,Yamaha etc
How can genuine gasser riders even recommend this shit !!! So much bad info posted
Old 02-18-2023, 07:04 PM
cbutler's Avatar
I got one about 5 years ago and it still works fine but if you want to.take your money and throw it out the window more power to you.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
WTB-Front Brake Nissin Master Cylinder 2010 or later. Moto7man "Wanted to Buy" & "Want To Trade" 25 03-13-2018 10:49 PM
Nissin master pump banjo bolt measures Fesart Enduro Chassis & Body 1 03-08-2015 12:30 PM
2002 EC300 front brake caliper (Nissin) Diedrix "Wanted to Buy" & "Want To Trade" 8 07-29-2014 12:48 PM
Nissin Master adddy Enduro Chassis & Body 2 07-17-2014 11:03 PM
'06 EC300 Nissin Front caliper brider Enduro Chassis & Body 7 12-01-2012 02:09 AM
