Old 06-12-2007, 07:02 PM
mike989 mike989 is offline
Talking Zerks for rear linkage?
Has anyone installed zerk fittings in there rear suspension linkage?
Euros don't believe in Zerks?
04EC300
04Wild450
07FSR450
Old 06-13-2007, 08:06 AM
jeffd jeffd is offline
Not having that zerk saves the manufacturer 39 cents. And they make alot of money selling bearings. It is not just a euro thing - even later model XRs no longer have zerks...
Adding zerks later is sometimes not a good idea. Drilling for the zerk can create a spot where a fracture can start in the casting.
Old 06-13-2007, 09:02 PM
Jeff is right. Just service the bearings with moly paste, use new o-rings, and keep the pressure washer away. The o-rings on the newer bikes provide a very tight seal. As an experiment, I weant a complete season(March through November) on my '03 with no regreasing. No problems, but I usually do a mid season service anyway.
BTW, Huskys come with Zerks. They also come with a real crappy system for keeping crud out (needle bearings with tiny built in seals). When you grease a Husky through a zerk, its eaisly purged past the seals. I doubt that would happen in the GG with those o-rings, without blowing them out.
Old 06-14-2007, 07:02 PM
Thanks guys. I'll just regrease them every year or so. Southern Nevada is not the water crossing capital of the nation, and I don't race or power wash.
04EC300
04Wild450
07FSR450
Old 06-14-2007, 09:14 PM
Brian VT Brian VT is offline
Must be nice ! If I don't go through mine twice a year I'm buying new bearings. There's mud in every race/ride here. The Jet Lube moly that GMP recommends is good stuff.
Old 06-16-2007, 10:34 AM
widebear's Avatar
widebear widebear is offline
Banned
I dont have grease nipples on my suspension but I do on the kickstarter, brake lever and foot pegs. Keeping the kicker well greased sure helps with its longjevity. I know that if you want to put a grease nipple into the dogbone it might be a crap shoot . I saw it once on a Yamaha and it developed a stress riser and blew the dogbone apart!
Old 06-17-2007, 10:06 AM
Eric K Eric K is offline
The new o-rings are much better than the old style seals. I ran an entire season of slop on my '06 and the bearings looked very good.
I use a #2 moly grease with the GC/LB spec on everything - motorcycle truck, tractor... The GC/LB spec means it is extreme pressure rated and high temp rated.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 06-17-2007, 06:50 PM
My drz has grease zerks in the linkage. When servicing it I noticed that they have a groove machined inside the bore so when you hit it with a grease gun the grease will move along the groove and distribute itself all the way around the bore. I don't think There are any grooves machined inside the bores on the gg linkage. In such a situation the grease may not even distribute around the way it should.
Swingarm and Linkage Bearings blitz11 Enduro Chassis & Body 34 01-12-2015 03:41 PM
Linkage redrider7202 General Discussions & Announcements 12 05-18-2010 09:05 PM
Linkage redrider7202 Enduro Suspension 1 05-12-2010 05:34 AM
Rear linkage brackets lower mount 3hunerd Enduro Suspension 2 10-16-2008 09:42 AM
