Old 08-21-2013, 10:55 AM
Jyrider Jyrider is offline
Default GG 280TXT Pro Tranny problem
Can anybody suggest a solution to my '06 GG 280TXT Pro shifting problems? I have trouble selecting 4th gear. The trans makes a grinding clunk sound and goes straight into 5th from 3rd. I can select 4th when I ride very slowly and before the engine warms up much. Also, downshifting is very "vague" and not very positive.
I've checked the eccentric adjuster as per the Video on Gasgas USA's website, and it "clicks" going into 1st and 2nd as the video says it should. My question is, does anybody know which direction I should turn the eccentric adjuster to try to "reset" the shift drum? I want to try that before I go changing out shift forks, gears etc.
I know that 4th gear is the most "complex" gear to select in the trans, but it should shift into gear with no problems. Any suggestions would be appreciated!
Thanks!
Old 08-21-2013, 11:59 AM
john r b's Avatar
john r b john r b is offline
Try trialpartsusa?/Rising sun imports. They should be able to help.
Old 08-21-2013, 03:29 PM
robicon robicon is offline
Oh that kind of tranny!
Old 08-21-2013, 10:54 PM
webmaster's Avatar
Administrator
The first person to talk to is rising sun imports.... The early pro models were very finicky...
Jeff
Aka webmaster
Sent from my HTC6435LVW using Tapatalk 2
Old 08-22-2013, 11:55 AM
Boom Boom Boom Boom is offline
06 is past the first years with clutch and tranny issues.
Jim Snell at Rising Sun would be your best place for info.
If you live on the east coast, try Stu at Jacks Cycles or PM Laser17 at ADV Rider, very much up on Gas Gas trials issues.
The ADV Rider trials forum has a bunch of trials guys that have good collective trials knowledge. You can always go to Trials Central, but I have had better feed back from the ADV Rider guys.
I would stop riding till you figure it out, you might have some broken metal floating around inside.
2014 Sherco SEF 300-R
2014 Sherco ST 300
2013 Sherco X-ride
Old 09-24-2013, 06:01 PM
trialsage trialsage is offline
maybe the split bearings-- the one on the secondary shaft always goes first-- best to replace both-- gotta take the engine out and split it.
Old 09-24-2013, 08:58 PM
Coop's Avatar
Coop Coop is offline
In my experience with my 1992 GasGas trials bike Scott Armstrong at MotoConnectionVT is great and very helpful. PM me if you want his email.
-Mike
2009 Beta Evo 300 4T - 1982 Suzuki PE175
Tags
4th gear, eccentric adjuster, gear shift, shift problem, transmission
Milky Tranny Fluid - my problem finally solved - may help someone DaveH Enduro Engine - 2 stroke 12 02-01-2014 10:55 AM
02 300 tranny jhendr3702 Enduro Engine - 2 stroke 4 09-30-2010 05:11 AM
New tranny technology lankydoug Enduro Engine - 2 stroke 4 09-23-2010 05:34 AM
Tranny oil for 00 GG 250 MC? scarylarry Enduro Engine - 2 stroke 7 08-05-2008 07:11 PM
tranny steve Enduro Engine - 2 stroke 2 03-26-2008 12:56 PM
