Spewing Gas
2007 EC300 2 stroke.
I have a problem where gas "pours out" of my overflow tube when I lean the bike on its kickstand after riding. If I stand the bike straight up the flow stops. Any ideas what's wrong? My riding partner calls my bike the "Exxon Valdez"
2007 EC300 2007 KTM XCFW 250 |
Set your float level, so it shuts the fuel down sooner. Probably 1 or 2 mm at most would do it.
All healed up, and ready to burn some fat. |
Common. Give it a small adjust. Its a bit of a small envelope. If it leaks when leant over a bit more than on stand but not when on it you've got it right.
It also helped on mine to make sure that the carb is rotated so that it is more straight up and down.
But mine still leaks anyways when not running. Doesn't seem to leak when on judging by the great mileage I get, lack of gas smell or sign of leaking. They do seem to be prone to do this more so than others.
-Keith '08 EC250 and some other bikes. |
replace needle under float tang and reset level
2013 ec200r |
This. Doesn't take much for the viton needle tip to allow some fuel past. A small piece of grit, some minor damage, or simply old age hardening/perishing the rubber.
Thread Tools | |
Display Modes | |
spewing rear brake | LAWMAN | Enduro Chassis & Body | 16 | 05-05-2008 03:26 PM |
