GasGas 300EC 2011 keep stalling without choke
Hi,
after about 15min of riding, my bike stall. It sound like something wrong in a the carburetor. After a couple of try to start the engine, it finally started and stall again after 1 min. keep doing that a couple of time until I can't started the bike anymore. I decided to turn On the choke and give a try and the bike started. I was able to get home with the choke On, but as soon as turn off the choke, bike stall. Any idea what could be the problem? Thanks |
Drop the float bowl and see if the pilot jet is plugged.
That's my first thought too!
Thanks guys. I will try that tomorrow and let you know. I have to look on-line, never done this before.
Cheers |
are you still using the cable choke? If so make sure that it is not engaging by mistake
https://whatimg.com/i/pfkULU.jpg |
That link gives error 403. Try imgur.com
Cut and past in your browser. I think the forum do this error.
Anyway, I want to say thank you to all of you for your support . I removed the Pilot jet and I think there was a little piece of dirt inside. Its hard to say because the hole is so small. After I blow in the pilot jet, the hole seems to be a bit bigger. I went for a 30 min ride and the bike runs like new. I can go riding tomorrow. Cheers |
The white arrow is pointing at the throttle cable.. If something is loose under the rubber sheath there I would tighten it. I doubt it is your problem though.
The choke knob is not cable operated from what I see in the picture. |
Thread Tools | |
Display Modes | |
2011 GasGas 300ec Race | jmille8651 | Used Bikes | 3 | 04-24-2015 04:34 PM |
More Parts from my 2011 300EC | iamovru | Parts | 3 | 09-16-2014 08:39 PM |
2011 300EC Gas Gas Parts for Sale | iamovru | Parts | 8 | 09-15-2014 03:24 PM |
2011 300EC Jetting | 400exc | Enduro Intake/Carburetion - 2 stroke | 7 | 04-04-2013 05:36 PM |
